Latest: lio94
Overall: 17181
Online Now [137]:
Visitors: 136
Today: 36750
Total: 141475749
Forums › The Car › 206 Talk › 180 Cam Belt Replacement
206-GTi
PostPosted: Fri Aug 27, 2010 7:34 am Up
Have to remove the battery/box etc and move the engine over I belive.
Its such a shame the air vent on the drivers side of the engine bay is welded on, would make things alot easier if it could unscrew.
GTi - Black - 2002
Felix.
PostPosted: Fri Aug 27, 2010 7:39 am Up
you dont need to touch the battery Smile
A life lived in fear is a life half lived
Jamie
PostPosted: Fri Aug 27, 2010 7:42 am Up
GTi180Boy will do it for £130 labour or £270 if he supplies the parts. It is a real pig of a job Rich, you need special timing tools etc.
LilLew
PostPosted: Fri Aug 27, 2010 7:58 am Up
I have heard very good things about him if you have never done a cambelt on a 16valve engine i would not recommend it my dad is a mechanic as well and he look at my 180 and said fcuk doing a cambelt on that it would be a pain in the a**e
2003 Pug 206 2.0 GTI 180
206-GTi
PostPosted: Fri Aug 27, 2010 8:14 am Up
Battery and box was removed when mine was done. As under it is the section which allows you to move the engine over.
GTi - Black - 2002
Ali_H
PostPosted: Fri Aug 27, 2010 8:26 am Up
You can't do it yourself without the correct tools as IIRC it has a floating crank. My mate's a senior technician at Ford and he had to buy the specific equipment to do it... which cost more than he charged me to do it Rolling On The Floor Laughing
kurtis wrote:
Felix.
PostPosted: Fri Aug 27, 2010 8:31 am Up
a trolley jack under the engine is also an option
Big_Rich180
PostPosted: Fri Aug 27, 2010 8:45 am Up
Thats the one i was going with Laughing
206-GTi
PostPosted: Fri Aug 27, 2010 9:01 am Up
Thats something you will defo need as well, cant balance the engine on nothing!
GTi - Black - 2002
PostPosted: Fri Aug 27, 2010 10:02 am Up
Quarmbo wrote:
alot!
In terms of the cambelt change there is little difference.
pastaboy
PostPosted: Thu Nov 04, 2010 6:12 am Up
Am relly interested in info on setting up new cam belt in a 206 GTI 180 (ie.. cam positioning with the locking pins) and how to tension the cambelt
Thanks in advance
Marc M
pastaboy55 @ hotmail.com
I always wanted to be somebody, but now I realize I should have been more specific.
glide
PostPosted: Sat Nov 13, 2010 9:39 am Up
in had a 180 cambelt changed 4 weeks ago , all parts supplied by a very good local motor engineers , and it was £237, that was a bargain then
vimeo.com/15204709
PostPosted: Sat Nov 13, 2010 9:57 am Up
LilLew wrote:
E5GDM wrote:
LilLew wrote:
a hanyes manual will help you or a autodata cd
Unfortunately the Haynes manual doesn't cover the 180.
well that is abit s**t what is the difference between the gti enginge and the 180
could we not use a gti manual
a LOT the timing is all totally different as the 180 has vvt and no keyway for the crank pulley
the haynes manual doesnt even cover the normal gti anyway
DO NOT attempt this unless you have the correct locking tools and confidence if you dont get it right you will be binning the engine!
-SDC-
PostPosted: Mon Nov 15, 2010 6:19 am Up
DONT TRY THIS YOURSELF.
Three specalist tools, my engine was basically taken out. The belt kits are expensive, I got mine from all parts for £90 including tensioners in the ends. Just say that to they that Euro Car parts are doing them for £92 or something.
My local garage charged me £200 to do mine. And they had two guys working all day on it. Went and spoke to one of the guys about it and he just said "what a complete pain in the ass!".
-SDC-
Did you walk in with a gun in your hand?
Page 2 of 3
