Latest: jackrox1992
Overall: 17186
Online Now [701]:
Visitors: 700
Today: 5439
Total: 148547024
Forums › The Car › 206 Talk › What is the best way to lift the rear of a 206?
Forum Index › 206 Talk
pete_206
PostPosted: Sat Aug 28, 2010 11:21 am Up
Very similar to my post the other day, only this time it's not just reassurance I need... I really am confused!
How do you lift both back wheels safely? I'm guessing I'de have to chock the front wheels heavily and leave the car in gear... but would that be sufficient?? Or is it a case of doing one wheel at a time? That'll take forever Sad
Low & Slow 1.4 8V glx
my 206 project page Smile
PostPosted: Sat Aug 28, 2010 11:23 am Up
Search Wink
206info.co.uk/Forums/v...11934.html
bertt
PostPosted: Sat Aug 28, 2010 11:32 am Up
just get a heavy duty jack and whack it in the centre of the rear near the anti roll bar, simples.
tofy92
PostPosted: Sat Aug 28, 2010 11:34 am Up
London Area Rep - tofy92
boo to the above u never work under a car if its only supported by a jack allways u some kind of stand
bertt
PostPosted: Sat Aug 28, 2010 11:41 am Up
haha, I use a big plate jack and just pop two tyres either side so if it drops itl land on them, the jacks safe as though is a trolley jack with the big head never gave me any problems.
PostPosted: Sat Aug 28, 2010 2:00 pm Up
You'll find that's the torsion bar and it's cetainly not designed to take a load equal to the whole weight of the rear end!
Using a trolley jack with a block of timber between it and the car on the end of each box section under the floor is fine to lift the rear end as it's so light.
bertt
PostPosted: Sat Aug 28, 2010 2:45 pm Up
no i wansnt on about the torsion bar I was on about the bit further down just passed where my back box ends, not the torsion bar because as you said it isn't designed to take that weight, the way you have described will work just as well though.
