Forums › The Car › 206 Talk › 206 gti rough running/increased revs/engine management light |
Posted: Mon Sep 06, 2010 1:30 pm |
My wife 206 gti has started to rough running/increased revs/engine management light when being started from cold? Any ideas chaps?
Posted: Mon Sep 06, 2010 1:36 pm |
plugging into computer will most likely give the fault as engine light has been on etc.
Posted: Mon Sep 06, 2010 1:44 pm |
Hydraulic lifters or coil pack are normal problems...if it will start but only run with throttle I'd blame the idle control valve...
