Online Now [155]:
Visitors: 154
Today: 58383
Total: 138848585
Forums › The Car › 206 Talk › two quick headlight questions
Rob2859
PostPosted: Wed Sep 08, 2010 1:25 pm Up
For my main beam so I can see further I have put 100w bulbs in. will they melt anything? as on some cars they do.
I found a phillips nut that turned a white sprocket. What does this do as I couldn't seem to figure it out?
Thanks guys Very Happy
PostPosted: Wed Sep 08, 2010 1:34 pm Up
Should be ok, just keep an eye on them. The 'nut' sounds like the headlight adjuster.
Rob2859
PostPosted: Wed Sep 08, 2010 1:37 pm Up
no the adjuster for the headlights in a different place. It didn't effect the full beam ether.
PostPosted: Wed Sep 08, 2010 1:43 pm Up
You should be fine to be honest.
There are 2 adjusters for the headlights one that electric and manual that does the up and down adjustment and there is on the is just manual that does the side to side adjustment.
Rob2859
PostPosted: Wed Sep 08, 2010 2:10 pm Up
thanks for the info. I think i was messing with the side to side ones then. they might be a bit wonky :S although they didn't seem to be doing anything
PostPosted: Wed Sep 08, 2010 2:11 pm Up
They would do mate you will see if you put your fall beam on and then move them
Rob2859
PostPosted: Thu Sep 09, 2010 6:19 am Up
Thats what I was doing but nether moved. it has confused me
