Online Now [161]:
Visitors: 159
Bots: 2
Today: 52010
Total: 138982526
Forums › The Car › 206 Talk › A Couple of questions really...
devildriverxii
PostPosted: Fri Sep 17, 2010 3:33 am Up
I've probably posted this in the wrong section as I always do, I can't seem to get the hang of it.
Anyways my 2 questions are this...
How do I remove my side repeaters, I just got some black tinted ones and I don't want to bugger it up (I have check the styling how to's but I couldn't see anything.
also.
How do I remove the badge from my boot strip? It's a phase one, and I can't afford a phase 2 yet, so I'm just going to paint the existing one, Any ideas, It looks like it should just pop out, but I don't want to dig about incase I mark anything.
Thanks in advance.
2002 1.6 5dr Black Edition.
sillyhilly
PostPosted: Fri Sep 17, 2010 3:37 am Up
206info wrote:
A collection of post from this board that tell you how to.
THIS SECTION IS STRICTLY FOR WRITING UP HOW TO GUIDES. ANY PROBLEMS/ QUESTIONS SHOULD BE DONE IN MAIN FORUM
Apparently, if you learnt to read basic instructions then you wouldn't 'always' post in the wrong section Confused
Either way, they pop out. Use a knife.
Hi Mikey Smile
VorTechS
PostPosted: Fri Sep 17, 2010 3:38 am Up
Staff - Vortechs
Moved anyway.... Wink
They should pull forward slightly. Look for a little clip that holds them in. Its one of them plastic U bend clips. Just carefully put a screwdriver between the wing and indicator and push the clip forward, then pull the indicator out. Disconnect the plug. Then put your new one in.
also.
Remove the whole bootsrip. Then From the inside push the clips and it will pop out. Smile
Thanks in advance.
Danw_VVT
PostPosted: Fri Sep 17, 2010 3:39 am Up
as tom said lol
devildriverxii
also.
Thanks in advance.
Legend, cheers.
anthony_839
PostPosted: Fri Sep 17, 2010 3:41 am Up
i just put my arm down between the door when its open and push it out from there
euroed astra
Quarmbo
PostPosted: Fri Sep 17, 2010 3:54 am Up
Yeah, the old how-to stated the following (or something similar):
- Open the door about half way
- You should then see (through the gap between the door and wing panel) two clips holding in the winker
- If you have skinny hands/arms, put your hand in the gap and push one of the clips in. If you have fat arms (like me), get a screw driver and push it in.
- This should 'pop' the winker out almost. Get half of it out and the other clip should just come through the gap.
- Change winker over, and push back through the hole into the clips clip back into place.
Ford SportGay-A
Quarmbo
PostPosted: Fri Sep 17, 2010 4:00 am Up
Removing Boot strip
- Open boot and pull the plastic cover off
- Remove two nuts off two screws poking out
- Then I think you'll have to squeeze in to clips to push the boot strip off
- Do what you want with the phase 1 strip, and put back on as above (In reverse)
That might be wrong, I did it about 2 years ago so my memory may not serve me well.
Ford SportGay-A
PostPosted: Fri Sep 17, 2010 4:02 am Up
Who's holding in their winker Sam?
Quarmbo
PostPosted: Fri Sep 17, 2010 4:05 am Up
You've heard it called a winker before surely?! Or is that just some inbred Leicester talk?!
Ford SportGay-A
PostPosted: Fri Sep 17, 2010 4:06 am Up
sillyhilly
PostPosted: Fri Sep 17, 2010 4:08 am Up
Aha!! You admit it Laughing
Hi Mikey Smile
Quarmbo
PostPosted: Fri Sep 17, 2010 4:12 am Up
Whatever chav boy. Go back to Chaventry! My area of Leicester is nice, its some other areas you should worry about (Braunstone ect). BY the way Gaz, we were robbed. You had 1 shot on target to our 10!!
Ford SportGay-A
twed207
PostPosted: Fri Sep 17, 2010 4:37 am Up
i think they used to be called winkers in the older highway codes?
probably b******s... lol
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
