Latest: KevinRC
Overall: 17137
Online Now [211]:
Visitors: 210
Today: 96536
Total: 111131028
Forums › The Car › 206 Talk › Door solenoid connector help
Mike
PostPosted: Fri Sep 24, 2010 10:17 am Up
Trade Rating: +28
Well I bought a new central locking solenoid motor and have to connect the purple end of this connector into it which is fine but the other end isn't quite working as I hoped!
I've pushed the wire into the small silver pin and crimped it tight and then when I press the pin into the block it goes all the way in but doesn't 'click' in place so it can essentially just fall out as soon as I connect the end bck to the solenoid.
I'm fairly sure they use this block else where on the car so wondered if anyone has ever worked with them before and could help?
Cheers.
kiph
PostPosted: Fri Sep 24, 2010 11:05 am Up
There will probably be a little pin on the silver connector that you need to bend out, so when you push it in, it will 'click' and lodge into place.
Kip - 2001 - 206 GLX - 1.6 - 16v - 110BHP
Wiliam_morgan
PostPosted: Fri Sep 24, 2010 11:16 am Up
failing that, get a glue gun and a tiny but of glue on it once it is in the term block. and i mean tinnnnny bit!
PostPosted: Fri Sep 24, 2010 1:42 pm Up
the silver pin need to be connected to a wire,and when you do,it will be thicker,and then it won't fall out anymore Smile
Mike
PostPosted: Fri Sep 24, 2010 5:00 pm Up
Trade Rating: +28
Cheers for the answers, I've had a look at bending back one of the little pins but can't see one that'd lodge in place and I've not got any spares unfortunately Sad
Timon, I've got all the cables attached in my other block and even with the wire attached they don't hold in :/
Mike
PostPosted: Sat Sep 25, 2010 12:06 pm Up
Trade Rating: +28
*Bump*
Mike
PostPosted: Sun Sep 26, 2010 11:15 am Up
Trade Rating: +28
*Bump*
PostPosted: Mon Sep 27, 2010 2:03 pm Up
well something is not right in this situation,maybe the plug is not the same model or specifications,i mean but it should stay empty like this is some models
