Latest: tebas93089
Overall: 17179
Online Now [243]:
Visitors: 242
Today: 40420
Total: 138093491
Forums › The Car › 206 Talk › How do you remove the gear stick?
Rob2859
PostPosted: Thu Sep 30, 2010 4:49 pm Up
There is a GTI gear knob on a car at the scrappers which i can not get off for the life in me. I think it may have been glued on. how easy is it just to take the whole stick itself?
also while I am at it how do I remove the glovebox lid? I am taking the full interior out of the car Smile
Iain
PostPosted: Thu Sep 30, 2010 4:52 pm Up
Just pull it, maybe twist and pull.
Never taken glovebox lid off, but I've definitely read how to do it on here several times.
Our snow > Your snow
PostPosted: Thu Sep 30, 2010 5:02 pm Up
Just pull it and mind your face when you do Wink
I had to have my lip stitched lol
Glove box you undo the troxs on hinge and then unhook them and the bar thing (unsure what the bar bits called)
Rob2859
PostPosted: Thu Sep 30, 2010 5:32 pm Up
cheers ben.
its not coming off both me and my mate have tried. it won't twist eather. i am aware how to get one off as i took mine off. this will seriously not budge and i can use maximum force as there is no gearbox in the car so i can move it in any direction i want
ukskater01
PostPosted: Fri Oct 01, 2010 12:46 am Up
Use a hacksaw and drill the stick out! Lol
Teebag
PostPosted: Fri Oct 01, 2010 1:06 am Up
1 bolt underneath the car to connect to gear linkage.
my garage inc mod list:
- Antix
glenpring
PostPosted: Fri Oct 01, 2010 2:30 am Up
my one twisted 1 quater turn then just pull
twed207
PostPosted: Fri Oct 01, 2010 2:35 am Up
yup, what glenpring said...
twist it quater turn (it's very hard) then pull the knob and watch it doesnt get you in the face! Rolling On The Floor Laughing
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
rudebwoi93
PostPosted: Fri Oct 01, 2010 4:43 am Up
Rob2859 wrote:
cheers ben.
If it still hasnt worked for you mate, if u just wanna remove the gear knob. Secure it at the lowest point, then use some big pliers around the bottom of the gear knob and just hammer the pliers, the whole knob should slide off the pole, including the white plastic bit inside! Thats how i did mine!
Rob2859
PostPosted: Fri Oct 01, 2010 11:12 am Up
rudebwoi93 wrote:
Rob2859 wrote:
cheers ben.
cheers for that. I can't get under it as its sat on the floor with no wheels
rudebwoi93
PostPosted: Fri Oct 01, 2010 2:18 pm Up
Rob2859 wrote:
rudebwoi93 wrote:
Rob2859 wrote:
cheers ben.
Depends on what you wanna do, if u just want the knob off, u can do it from inside the car, just some big pliers (cant remember what they called) around the bottom of the gearknob, and smash the pliers with the hammer and itll slide off, this is actually the best way, because a lot of people twist and turn it, and then they end up breaking the white plastic bit.
sam-c
PostPosted: Sat Oct 02, 2010 3:53 am Up
Yorkshire Area Rep - SamC
if your really struggling get some sort of grips round it i think there's a set called mole grips which are quite large that should do the job
