Latest: Stu-mill
Overall: 17131
Online Now [212]:
Visitors: 211
Today: 69639
Total: 104755213
Forums › The Car › 206 Talk › bolt size
bolt size
sam-c
PostPosted: Fri Oct 01, 2010 1:44 pm Up
Yorkshire Area Rep - SamC
hi guys
strange question but what size spanner do i need to undo the bolt for the rear seat belt?
im at uni so dont have a spanner set as stupidly left that at home and i need to undo the bolt so i can try re-grounding my amp and i dont want to have to buy a full set as im skint! haha
thanks
sam
Dillon
PostPosted: Fri Oct 01, 2010 1:46 pm Up
Staff - Dillon
17mm iirc
sam-c
PostPosted: Fri Oct 01, 2010 1:49 pm Up
hmm i thought it was bigger than that but ok thanks Dillion Smile
Ruffy_206
PostPosted: Fri Oct 01, 2010 2:00 pm Up
Custom - Gold Stars
16 or 17 i no thats what you need to get the rear doorcard off as the top of the front one is different size to the bottom two.
PostPosted: Fri Oct 01, 2010 2:01 pm Up
17mm because i used the tyre wrench
brad-morris
PostPosted: Fri Oct 01, 2010 2:02 pm Up
deff not a 16, its a 17mm
PostPosted: Fri Oct 01, 2010 2:03 pm Up
19mm
Ruffy_206
PostPosted: Fri Oct 01, 2010 2:05 pm Up
Custom - Gold Stars
one of them is a 16 i can bet on it my rear doorcards have been off more than i care to rember Very Happy
brad-morris
PostPosted: Fri Oct 01, 2010 2:09 pm Up
Laughing
Ruffy_206
PostPosted: Fri Oct 01, 2010 2:15 pm Up
Custom - Gold Stars
1. to get rid of the standard speakers. 2 to deadening it. 3 to put some foam in thier to stop noise.4 to try and fit 6x9 in thier cuz i found some in the garage.5 to fit some better 5 inch speakers in thier 6. to fit some 6inch speakers in thier and thats off the top my head im sure its been off a few more times.
Wiliam_morgan
PostPosted: Fri Oct 01, 2010 2:36 pm Up
its M10 bolt - 17mm socket/spanner is needed.
sam-c
PostPosted: Fri Oct 01, 2010 5:11 pm Up
ok im not sure im using the same seat belt bit as the rest of you im using the one in the rear 3 quater if you remove the carpet on the side of the boot ... maybe this is why im having problems hmm
Ruffy_206
PostPosted: Sat Oct 02, 2010 3:55 am Up
Custom - Gold Stars
uumm avent a clue not the clamp down in the bottom couner of the boot? Or the light earth point? Behind the boot side carpet?
A pic is need lol
