Latest: jackrox1992
Overall: 17186
Online Now [455]:
Visitors: 454
Today: 163532
Total: 147874482
Forums › The Car › 206 Talk › GTI 180 Dyno Results Question
Forum Index › 206 Talk
Go to page 1, 2, 3  Next
Gems
PostPosted: Sat Oct 02, 2010 9:38 am Up
South East Area Rep - Gems
Hi guys, had my car Dyno'd today @ Talk of The Devil in Uxbridge.
BHP came out at 163 and Torque came out at 140lbs/ft
Was wondering if this normal for a 180?
I've got a Pipercross Viper Induction and Scorpion Exhaust. All the fuel ratio reading are fine and the car is running fine.
Gotta admit was gutted as was expecting alot better from it. Dyno was reading correctly.
Mattie-RS
PostPosted: Sat Oct 02, 2010 9:43 am Up
Aye, all 180's get around the 160-170 BHP mark im afraid
PostPosted: Sat Oct 02, 2010 9:49 am Up
True what Mattie said. Wouldnt be to hard to get a bit more power out of it tho just depends on how much you want to spend
no_offences
PostPosted: Sat Oct 02, 2010 10:05 am Up
yerah its normal, tarmac terriorist on here has one with 180 but thats with hours remapping it at rs tuning lol most pull that figure, most are towards the high end of 160
Signature removed due to size
PostPosted: Sat Oct 02, 2010 10:28 am Up
If that's 163bhp at the wheels, that's pretty good. That would be near enough 180 @ the flywheel, the figure pug quoted & named the car after.
Gems
PostPosted: Sat Oct 02, 2010 10:30 am Up
Its 163bhp at the flywheel. Thanks for the replies feel better now lol
Antix
PostPosted: Sat Oct 02, 2010 10:38 am Up
Custom - Red Stars
If it was 140nm torque it is 103.26lb.ft - that's one very sick puppy Confused
If it was 140lb.ft, it is pretty low for a 180
EDIT: my figures (12/9/09) are 167.4bhp/153lb.ft (Viper & Janspeed)
Schumi
PostPosted: Sat Oct 02, 2010 12:19 pm Up
Check you VVT selenoid. If it fail you can never seen any CEL or diagnostic information.
2005 206 RC RED
Ali_H
PostPosted: Sat Oct 02, 2010 12:26 pm Up
Mine put out 169.9 with a Pipercross induction kit on it. I've not had it done with the Janspeed on it though.
kurtis wrote:
Big_Rich180
PostPosted: Sat Oct 02, 2010 1:15 pm Up
If it helps the clio's are the same, i think a few VW's are the same aswel. For some reason they just dont make the power and pug took it upon them selfs to lie about the output.
Antix
PostPosted: Sat Oct 02, 2010 1:25 pm Up
Custom - Red Stars
VW 'usually' underquote their figures.
This year's RSTuning saw my Golf TSI at 160.4bhp/180lb.ft at 1000 miles (VW figures 160bhp/177lb.ft). Most of the other cars were under-performing due to the hot weather
no_offences
PostPosted: Sun Oct 03, 2010 1:20 pm Up
why do they need to lie, they did'not with the original gti
Iain
PostPosted: Sun Oct 03, 2010 1:23 pm Up
Think it was to compete with the Clio 172/182 that it was targeting.
Our snow > Your snow
SAB206
PostPosted: Sun Oct 03, 2010 1:24 pm Up
180's come out the factory with 177ps, which is 173bhp standard?! roughly? so not far off..
Your torque seems a bit low..
mine standard was 161.6 bhp and 147 torque, then with new filter and exhaust was 169,2bhp and 154 torques.
www.sab-graphics.com
I AM SYDLEXIC!
ben_w_gti
PostPosted: Sun Oct 03, 2010 2:25 pm Up
chances are that your car will be less power than standard if it has the pipercross and the scorpion exhaust. everybody puts them on as they think it gains you power when nine times out of ten you actally lose power. the extra noise makes you think its quicker lol. most induction kits are fitted incorrectly causing warm air to be sucked into the engine therfore resulting in loss of power, ( if they were that good wouldnt all car manufacturers fit them to hot hatches as standard if its such a cheap easy way to gain bhp) and the exhausts normally cause you to loose back pressure again resulting in power loss. my friend has a megane f1 230, had it on the rolling road, then fitted a K & N induction kit and rolling roaded it again the same day and the loss was incredible, 13bhp iirc. you notice more difference by running your car on higher octane fuel and keeping your tyre pressures correct than changing an air filter or exhaust.
BEN_W_GTI
Page 1 of 3
