Online Now [259]:
Visitors: 258
Today: 48157
Total: 142861609
Forums › The Car › 206 Talk › Roof scoop anyone done one ?
Go to page Previous  1, 2
MFACTOR001
PostPosted: Thu Oct 07, 2010 4:00 am Up
If I do not go ahead with the roof scoop I will be looking into other ways to get air in to the compartment where your drivers side leg sits
Maybe cut a hole out and duct air to it ?
Any other suggestions ?
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
I make no appolagies for spelling punctuation
Spanerman
PostPosted: Thu Oct 07, 2010 4:53 am Up
A 206 allready has vents to channel air into the cabin, cutting the roof will play help with your resale value
Sam.
Hello
sillyhilly
PostPosted: Thu Oct 07, 2010 4:59 am Up
Surely a bonnet one is better than the roof? Confused
Hi Mikey Smile
Drake
PostPosted: Thu Oct 07, 2010 5:29 am Up
Only look decent on Rally cars IMO.
54' 206 GTi 180 Silver - K&N panel filter, Scorpion cat back exhaust, Parada Spec 2s
rudebwoi93
PostPosted: Thu Oct 07, 2010 5:58 am Up
Lol, @ posters on page 1. (PS sorry for trolling op!!) I hooked up my old xbox jsut to play it again, around about the time we started looking for a 206 lol!!
Lecktorious
PostPosted: Thu Oct 07, 2010 6:33 am Up
Trade Rating: +59
Roof scoop on a tractor? Jesus...
'98 Nile Blue 306 GTi 6
MFACTOR001
PostPosted: Sat Oct 09, 2010 4:41 am Up
lol tractors use snorcals
MFACTOR RAP1D HDI
MFACTOR001
PostPosted: Sat Oct 09, 2010 4:42 am Up
The bonnet vents no longer exist custom bonnet now on
MFACTOR RAP1D HDI
st3v3n
PostPosted: Sat Oct 09, 2010 5:17 am Up
Bit of a s**t way of doing it don't you think? Why not take the air from inside the wing? Just fabricate something to stop the s**t getting in.
ICE goes in drinks. NOT in cars.
MFACTOR001
PostPosted: Sat Oct 09, 2010 9:34 am Up
Ye will probably go down that road for the browsers
I was thinking about adding the roof scoop but don't want it just purely causing drag rather it put air somewhere.
MFACTOR RAP1D HDI
Rob2859
PostPosted: Sat Oct 09, 2010 6:39 pm Up
why not put a vent in the wing?
macj
PostPosted: Sun Oct 10, 2010 2:35 am Up
Just an idea... why not fit the vent in your door card, If you remove the front arch liner you can see thru to the leading edge of the door, Cut a hole below the wiring duct, add a peice of ducting of your own. Refit arch line to act as splash guard and you will get air from outside and no visible vent hole..... Mini dash vents or similar would mount in your door cards
PhillipM
PostPosted: Sun Oct 10, 2010 3:12 am Up
One on the rear clamshell of the rally car but it's there to blow cool air across the bulkhead to block some of the engine heat from the cabin.
206 GSR Evo9/10/HSX rally cars.
620+bhp, 4wd, 7 speed sequential gearbox = fun.
Page 2 of 2
