Latest: Worthy967
Overall: 17143
Online Now [67]:
Visitors: 65
Bots: 2
Today: 25611
Total: 114925994
Forums › The Car › 206 Talk › 206 hdi buying guide
iansgtihdi
PostPosted: Mon Oct 11, 2010 1:51 pm Up
Hi people. I'm hoping to buy a 206 2.0 hdi soon. I've got about £2500-3000 to spend. Knowing what kind of age/condition car this will get, what things should i look out for? i've never had an older higher mileage car before. Also where to look other than autotrader or ebay? If anyone can point me in the right direction would be much appreciated.
Twidly
PostPosted: Mon Oct 11, 2010 1:55 pm Up
Try pistonheads.co.uk... But I found mine on Autotrader. You should get one about 03 plate/about 60000-80000 miles... So that's not bad. You need to see if it's had it's cambelt done, or if it's due to be done. Also check the exhaust & ball joints & such. Check the condition of the radiator too for rust & decay!
iansgtihdi
PostPosted: Mon Oct 11, 2010 1:59 pm Up
thanks twidly. How do you check ball joints? Are the engines ok with that kind of mileage?
Twidly
PostPosted: Mon Oct 11, 2010 2:05 pm Up
The engine's are fine! Mine's done 92K & it sounds like a dream. My Mum's has done 110K & drives perfectly. Diesels will run forever!
IIRC you have to stick a screwdriver in it & wiggle it or something... I think it's not supposed to move a lot... someone else with more knowledge on that will no doubt provide you with better information. Cause I haven't actually done it myself, just know it should be done as they're notorious for clunking & failing MOT's.
PostPosted: Mon Oct 11, 2010 2:16 pm Up
Ask if the crank pulley has been changed as well, because they are a common fault on the hdi
PostPosted: Mon Oct 11, 2010 2:22 pm Up
is there any symptoms that the pulley is going to fail? Confused
PostPosted: Mon Oct 11, 2010 2:24 pm Up
Rattles and like a metallic sound. You can see it wobble a bit as well.
Mine fell off on the M1 Laughing
BarneyBaloo
PostPosted: Thu Oct 14, 2010 3:42 am Up
Trade Rating: +23
my hdi's on 124k and running spot on Smile best engine to come out of france
Antknee
PostPosted: Thu Oct 14, 2010 3:54 am Up
What He Said
Mines on 105k and still going strong! only problems i've had with it are actually nothing to do with the engine!
