Posted: Tue Oct 12, 2010 9:59 am |
im guessing but think its around 110.
Posted: Tue Oct 12, 2010 10:11 am |
So, if i want to upgrade the brakes on my 2002 XSi (1.6 16v) I can swap them for the 406 V6 ones and they go straigh on?
What brake pads do I fit? (without sounding really stoopid im gunna guess the 406 V6 pads.)
Posted: Tue Oct 12, 2010 10:15 am |
| ICE goes in drinks. NOT in cars. | |
Posted: Tue Oct 12, 2010 10:22 am |
Posted: Tue Oct 12, 2010 10:23 am |
so what is the 85 or 86 or 87 or ??????????????????
Posted: Tue Oct 12, 2010 2:12 pm |
Trade Rating: +45
what would you need then to get the fiat ones to fit as i wouldnt have a cluew what to look for ???
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Tue Oct 12, 2010 2:18 pm |
a bracket made up that will bolt onto the fiat ones and then onto the mounting points.
look on the white noise project thread the racer one he has got a bracket for his but think his are different brembos again but same princable
Posted: Tue Oct 12, 2010 2:21 pm |
I wouldn't want to trust some company to make them for me, what if the bracket snaps when braking hard, is there any ready made available that have been tested?
Posted: Tue Oct 12, 2010 2:23 pm |
nope its not something people make as far as im aware. if you want off the shelf jobs look at hi spec or simlar.
Posted: Tue Oct 12, 2010 2:32 pm |
Ruffy_206 wrote: |
nope its not something people make as far as im aware. if you want off the shelf jobs look at hi spec or simlar. |
okay cool, thanks for the info
Posted: Tue Oct 12, 2010 2:45 pm |
or just get the 406 brembo lol
Posted: Tue Oct 12, 2010 3:10 pm |
They are at 82mm centres. I was only saying that what's the point in guessing and being wrong? It doesn't help.
Posted: Tue Oct 12, 2010 3:13 pm |
Golfguy206 wrote: |
What brake pads do I fit? (without sounding really stoopid im gunna guess the 406 V6 pads.) |
I'm fitting v6 brembos on my XSi with the 406 master cylinder (purely because I have a full v6 I can take appart and use whatever I need). I'd advise to use the bigger master cylinder as it'll help improve the feel of the brake and travel as well.
The pads you use are the same on all the brembo 4pots from different cars but the oem ones will be all the same, just depends if you want to use something better like tarox, red stuff etc.
I'm going to be running brembo max pads and c4 vts brembo max vented discs with mine.
Posted: Tue Oct 12, 2010 3:20 pm |
st3v3n wrote: |
They are at 82mm centres. I was only saying that what's the point in guessing and being wrong? It doesn't help. |
becuase i was under the impression he had fiat ones which i no dont fit so just guessed the pug one i new it was smaller tho.
in my eyes ive helped the op more than you have. and arnt you ment to be a brembo specailist..............
