Latest: Worthy967
Overall: 17143
Online Now [544]:
Visitors: 543
Today: 129933
Total: 114706057
Forums › The Car › 206 Talk › Noob wiring earth question
davieboy86
PostPosted: Wed Oct 13, 2010 7:25 am Up
Just wondering I have found some earth-ing points on my motor while wiring my fog lights but the wires i have are too short, can I just buy any wiring and connect it all up.
I have no electrical shops near by so I was just gonna use any wiring that I could buy from wilkinsons, is this safe lol ?
Thanks for any help
Danw_VVT
PostPosted: Wed Oct 13, 2010 7:27 am Up
as long as its same thickness and you connect it to existing wire correctly and safely then yes. should be fine Smile
Jon
PostPosted: Wed Oct 13, 2010 7:28 am Up
What She Said
Alpine 9887r
Genesis Profile 2 > JL C2 Components
Vibe BlackAir 12" Active
Wiliam_morgan
PostPosted: Wed Oct 13, 2010 7:58 am Up
yerh as long as the wire is the same or a little bigger you wont have a problem! obv not to big but be sensible. 2.5mm should be sufficant.
Danw_VVT
PostPosted: Wed Oct 13, 2010 8:03 am Up
Jon wrote:
:whatshesaid:
hahahaha im laughing so hard! Shocked
ok i am now lol
Jon
PostPosted: Wed Oct 13, 2010 8:06 am Up
dan_pug206sport wrote:
Jon wrote:
ok i am now lol
Wink Wink
Alpine 9887r
davieboy86
PostPosted: Wed Oct 13, 2010 9:11 am Up
Ah ok cool, so I could just buy some cable from Wilko s and do away with the existing wire I have to avoid getting an un-matching thickness.
The wire I saw in there on my lunch break was a standard White insulated cable with two wires in there, im thinking I could just strip the outer white plastic off and use either the green or brown wires that are inside. This isn't going to blow me up is it?
Thank for the quick reply guys
Danw_VVT
PostPosted: Wed Oct 13, 2010 9:19 am Up
if its only fogs your earthing then yes but i would recommened taping up with black insulating tape so it can be seen as more of an earth then if the cable is red or blue.
PostPosted: Wed Oct 13, 2010 9:47 am Up
you talking about mains cable by the sound of it??? it would work for a bit(could use the green/yellow earth) but personaly, for only a few quid most motor factors sell on rolls.
davieboy86
PostPosted: Wed Oct 13, 2010 9:57 am Up
I can't drive because the bumpers off and no garages around here to get some, it probably is a mains cable, when you say it'll work for a while, does that mean it could fail on me relatively soon ?
Wiliam_morgan
PostPosted: Wed Oct 13, 2010 10:12 am Up
Take it from me that wire u seen is plenty good enough! The cable u seen was called "flex" and one of the cores inside is sutible! I do this sort of thing For a living Smile
davieboy86
PostPosted: Wed Oct 13, 2010 11:07 am Up
Sweet man I'll grab some now I'm finished, almost there on my bumper respray and fog installation.
Argh, I need eye connectors or something now to connect up to the earth point, always something else I need to get, wonder what it will be next lol
Wiliam_morgan
PostPosted: Wed Oct 13, 2010 12:22 pm Up
u mean crimps Smile good luck withe the job dude few tips
1. Rough up the contact area revealing bare fresh un-oxidised metal
2. If u want mark the cable as an earth could do this in two ways either green and yellow tape nd wrap abit around or you could ferrul the cable as "C 90" , both these are international simble of earth!
3. Take your time Smile and if in doubt ask Razz
Wiliam_morgan
PostPosted: Wed Oct 13, 2010 3:21 pm Up
davieboy86
PostPosted: Wed Oct 13, 2010 3:50 pm Up
Cheers for the advice man, I'll definately ask, its the first real electrical thing I've done on the car besides the sub and amp so it's all a learning process.
