Online Now [470]:
Visitors: 469
Today: 34369
Total: 138602811
Forums › The Car › 206 Talk › Where to fit air filter?
Spanerman
PostPosted: Wed Oct 20, 2010 5:37 am Up
Right i need to get rid of the standard air box as the induction point is far to low for my intended use, im going to be doing a few few water splashes ect
I have a cone filter here and im wondering where to fit it, directly to the TB or before the second air box thing
The car is a 1.6 8v XS 2000
Please help, Sam.
Hello
Danw_VVT
PostPosted: Wed Oct 20, 2010 5:39 am Up
directly on the TB produces a big noise and the filter gets very hot there..... i tried. lol
tbh if its for performance then go for a panel filter. much better.
Rob2859
PostPosted: Wed Oct 20, 2010 5:47 am Up
a cone will provide you will less protection. The standard system has a foam pipe to absorb water. Its also in the wheel arch and has a long way to travel. I drove in a ford with the water coming over the bonnet and it was fine. if i had a cone filter on it would have killed it
Spanerman
PostPosted: Wed Oct 20, 2010 5:54 am Up
Well last time i drove through anything deep it destroyed the cardboard filter and got stuck in the throttle body.
So mounting to the TB with a cold air feed would be ok?
Sam.
Hello
Rob2859
PostPosted: Wed Oct 20, 2010 5:58 am Up
how deep? if you use a cold air feed its just going to give the water a direct path to your engine. The standard intake means the water has to come down through the top of the arch, round a bend then back up again into the airbox.
you could always put some foam sponge inside the airbox to offer better protection.
Danw_VVT
PostPosted: Wed Oct 20, 2010 5:59 am Up
Rob2859 wrote:
how deep? if you use a cold air feed its just going to give the water a direct path to your engine. The standard intake menas the water has to come down through the top of the arch, round a bend then back up again into the airbox.
+1
even with a cone and cold air feed you still wont be getting any increase. induction kit increasing performance is a myth really. they are jsut for noise.
Rob2859
PostPosted: Wed Oct 20, 2010 6:02 am Up
dan_pug206sport wrote:
+1
just for your benifit replace the standard pipe from the bottom of the airbox as that is the restrictive part of the system. i did and found it made a difference.
Spanerman
PostPosted: Wed Oct 20, 2010 6:05 am Up
I dont want the increase in power as such....
I just want to have less risk of sucking up water.
Noise would be nice but thats not my aim..
Sam.
Hello
spud_owen
PostPosted: Wed Oct 20, 2010 6:06 am Up
+1
they do increase throttle response abit as well though. Just get a K&N panel filter and use the standard set up, ive had to replace my pipe though as water kept getting in somehow, just used an assortment of old rainwater pipes that where lying around site, looks a proper job now!!
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
Danw_VVT
PostPosted: Wed Oct 20, 2010 6:07 am Up
probably putting it pointing down in the area behind the passenger headlight? that would be ok i guess?
Rob2859
PostPosted: Wed Oct 20, 2010 6:14 am Up
the standard airbox will offer the most protection. check the intake pipe below the airbox to make sure there is not a rip in the fabric. as tis just foam inside that
EDIT: if that is not good enough. then you may need to consider a Land Rover...
spud_owen
PostPosted: Wed Oct 20, 2010 6:19 am Up
is this directed at me? on mie the plastic was feck completely, hence why ive re fitted all now, the pipe ends up just behind the passenger head light, you would have to go through some serious deep water very slow to fill it i think!
Rob2859
PostPosted: Wed Oct 20, 2010 6:21 am Up
no to sam. i still wouldn't trust it tbh.
ExoVyper
snorkel!
hobnob48
PostPosted: Wed Oct 20, 2010 6:50 am Up
I agree with ExoVyper. Snorkel it if you are doing some serious underwater driving. Please share with us what you are going to be doing in a 206 that involves a lot of water Smile
