Latest: jackrox1992
Overall: 17186
Online Now [551]:
Visitors: 550
Today: 66928
Total: 147793809
Forums › Tuning, Modification & Legal › Project Cars › GTi Track Car
GTi Track Car
Go to page Previous  1, 2, 3, 4, 5 ... 9, 10, 11  Next
st3v3n
PostPosted: Sun Oct 17, 2010 10:21 am Up
ICE goes in drinks. NOT in cars.
st3v3n
PostPosted: Sun Oct 17, 2010 10:22 am Up
If I was scene then This would all be kept top secret Uk eyes only.
But I'm not so here goes.
First mask the garage off. To stop our s**t getting covered in overspray and to keep draughts at bay.
A nice dusting inside and out in high build primer
Roof given it's top coat tonight. ( pics didn't turn out to good due to the light in there)
The inside and the reat of the outside are going white with red and black WR signage
st3v3n
imjeeves
PostPosted: Sun Oct 17, 2010 10:37 am Up
Very nice.
Looks a lot like mine now!! sadly you have caught up with me very quickly. Whats next?
Teebag
PostPosted: Sun Oct 17, 2010 1:09 pm Up
looks a top job matey! just read whole thread!
my garage inc mod list:
- Antix
imjeeves
PostPosted: Tue Oct 19, 2010 4:27 pm Up
What size and offset wheel have you got? Looks nice and i need to order mine soon but not sure of the sizes.
st3v3n
PostPosted: Wed Oct 20, 2010 3:07 pm Up
They are pro race 1.2's in a 6 x 15 et25 (106 fitment) with 195/50 15 R888 tyres. the rear arches need rolling in to clear (lowered 1 notch)
imjeeves
PostPosted: Wed Oct 20, 2010 3:59 pm Up
Sorry mate i meant the OMP steering wheel?
Lecktorious
PostPosted: Wed Oct 20, 2010 4:02 pm Up
Trade Rating: +59
I didn't think you'd be using the 'notch' method given the standard of the other works!
'98 Nile Blue 306 GTi 6
wardie_206
PostPosted: Wed Oct 20, 2010 4:04 pm Up
Looking really good mate.
Brian
PostPosted: Wed Oct 20, 2010 5:33 pm Up
Trade Rating: +31
Loving this project mate! Nice to see things being done properly...apart from the rear axle Razz
st3v3n
PostPosted: Thu Oct 21, 2010 6:26 pm Up
When I say lowered 1 notch, I actually meant, the rear ride height was measured, the rear beam stripped, bearings/stub axles checked and greased then reassembled but with a new ride height 30mm lower than previous. I didn't realise that was such a crime! What is the correct way of doing it then?
st3v3n
PostPosted: Thu Oct 21, 2010 6:38 pm Up
Its a 350mm OMP WRC. 70mm dish
Demon Tweeks Tell them it costs too much and you can get 20% of most of their prices.
imjeeves
PostPosted: Fri Oct 22, 2010 4:12 am Up
Cheers mate
To do the ride height correctly you want to:
1. jack the car up at the back.
2.Remove both rear wheels
3. Measure with a tape measure from the center of the rear hub to the middle of the arch and record the measurement.
4.Remove the torsion bar for that side of the car.
5. If you want to lower 30mm then move the rear arm up that amount i.e if it was 150mm you put it up to 120mm from the arch
6. Attempt to slide the torsion bar back into place rotating it one spline at a time as it will only for on the correct rotation.
7. Do the same for the other side of the car.
The rotate one spline damages the bars if you run it like that.
Hope this helps
PostPosted: Fri Oct 22, 2010 7:12 am Up
looks good but surely would of been better to remove the clip on sp arches before painting??
Page 4 of 11
