Latest: Kifi69
Overall: 17183
Online Now [327]:
Visitors: 327
Today: 164882
Total: 144004850
Forums › Tuning, Modification & Legal › Project Cars › ZiAn's pride & joy 206GTi (EW12J4 in progress) pg.9
Go to page Previous  1, 2, 3 ... 7, 8, 9 ... 11, 12, 13  Next
=ZiAn=
PostPosted: Thu Nov 04, 2010 9:16 am Up
Thanks Jamie, I'll contact you when the funds will be available if you'll still have it Wink But we need to sort out the mechanical things first before we move onto electronics Smile
ZianDesigns - Website designs
=ZiAn=
PostPosted: Sun Nov 07, 2010 12:10 pm Up
Guys help me out, I need some tehnical help =) Does anybody know the size of the five bearings on the GTi cams? We're wondering if we could fit cams for the GTi into the ew12 engine so could anybody shed some light on the subject please Smile
PostPosted: Sun Nov 07, 2010 12:19 pm Up
Do the balancing shafts make the sump deeper than the one on the EW10?
Do you want measurements from both 138 cams? I've got some wrapped up in a cupboard upstairs. If you want any measurements let me know. I've also got a Piper 270 degree inlet cam to measure.
PostPosted: Sun Nov 07, 2010 12:55 pm Up
This is the inlet cam. I've just measured the max lobe diameter and the minimum and the difference is 8.8mm so I think it's a standard cam. I'll have to compare it to one i have in another head which is known to be standard.
Anyway, starting at the pulley end of the camshaft, the bearings meaure:
29.96mm, 29.48mm, 28.98mm, 28.43mm, 28mm.
Do you want the exhaust cam measurements too?
=ZiAn=
PostPosted: Sun Nov 07, 2010 5:28 pm Up
Thanks Edward, I really appreciate it. Could you please also measure the exhaust one, though I presume it should be the same.
As for the sump we haven't measured it but as far as I can remember it's quite a bit deeper.
=ZiAn=
PostPosted: Tue Nov 09, 2010 5:17 pm Up
Let's continue:
Thanks to Edwards measurements we now also know that the GTi cams will fit as the bearings match Wink
All the pistons and cylinders were measured and we came to the conclusion, that the engine is in good condition. There is 0,05mm play between the cylinder walls and piston skirts. there is also no damage visible to the piston ring beds so the engine. We still need to check the main shaft bearings, because we ran out of time yesterday.
This is how the tool for measuring cylinders and pistons looks like:
Dirty four and some other parts:
We've also measured distance between the valves and pistons at TDC. Due to the intake valves the piston cutouts will need to be a bit deeper but the exhaust ones have enough clearance. Max lift with the standard valve springs was also measured and we will need to change them as they would cause coil-bound with the chosen cams at max lift.
JLD Performance
Lecktorious
PostPosted: Tue Nov 09, 2010 5:19 pm Up
Trade Rating: +59
One of very few 'proper' project threads on here.
Thumb Up
'98 Nile Blue 306 GTi 6
PostPosted: Wed Nov 10, 2010 4:29 pm Up
Just noticed the EW12 head has a big E2 embossed onto the end. The EW10 has E0 on the end of it. Anybody know what the 180 has?
=ZiAn=
PostPosted: Thu Feb 24, 2011 7:38 am Up
@Edward, I believe it has a E1 but I'm not sure, It's been a long time since I've seen one. Nicely spotted btw.
Okay let's get you guys up to speed. Not much has happened since last time I posted, but let me just list the stuff.
I bought 16 new hydraulic lifters as they seem to be causing problems for me on the current engine and I didn't want to take any chances with the new one. Also one of the original ones was already broken and two were stuck if I remember correctly.
Also the guys at JLD Performance are putting together a flow bench (for the obvious reason).
All the pistons have been cleaned and the engine block was also scrubbed. So it's all nice and shiny...sort of Smile
And now all the small parts are being bought like main bearings, piston rings, semerings, etc. Then we're moving on to the more expensive parts such as camshafts, springs pulleys.
So I'll keep you updated as much as possible.
Oh and by the way here a pic from a very nice afternoon trip:
Schumi
PostPosted: Thu Nov 17, 2011 2:51 pm Up
Any update ?
2005 206 RC RED
spike_202
PostPosted: Tue Dec 13, 2011 8:01 pm Up
Hay zian how did you fit the 180 speedo to the standard gti? As I wanted to do this??
Thanks rich
**spike's project**
TEAM:+200bhp
Schumi
PostPosted: Wed Dec 14, 2011 10:24 am Up
This gti already multiplexed. So that speedo direct fitment for this car. And nearly impossible to work on preplexed cars.
2005 206 RC RED
spike_202
PostPosted: Wed Dec 14, 2011 2:42 pm Up
nice one i didnt realize this was plexd i was just lookin for a bit more range on mine.
**spike's project**
TEAM:+200bhp
=ZiAn=
PostPosted: Thu Dec 22, 2011 6:33 pm Up
Hey, long time no update Smile There were quite a few changes since the last update, but sadly the engine is still not in Sad Anyway, I will make an update shortly (preferably before new year lol)
@spike, as Schumi said its a plexed car so I only had to change the speedo. Don't know how much work would involve to put it in a preplexed one or if it's even possible :/
Ahoward87
PostPosted: Tue Jan 17, 2012 10:34 am Up
This is a great read and some great explanations there.
Any more updates mate? Smile
If life passes you by...... Shift down!
1/4 mile: full interior and sound system.
Reaction: .6067 60 Ft: 2.3343 330Ft: 6.6654 1/8 ET: 10.2421 1/8 MPH: 68.70 1000' ET: 13.2334 1/4 ET: 15.9189 1/4 MPH: 86.35
Page 8 of 13
