Online Now [523]:
Visitors: 523
Today: 84161
Total: 105412593
Forums › The Car › 206 Talk › Full Beam - Rally Bulbs?
Go to page Previous  1, 2
Lewis1304
PostPosted: Thu Nov 11, 2010 5:30 pm Up
Will get them Dab, Yh I have angels and to be honest I have HID in main beam and the light output is fine Smile Full beam is what I need to uprate...
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
Dabamash
PostPosted: Thu Nov 11, 2010 5:31 pm Up
Staff - Daba
Make sure you get the towers of 9 or more SMDs on each side, or the output won't be comparable to normal sidelights.
kingdom200
PostPosted: Fri Nov 12, 2010 12:17 am Up
i know quite a lot of people that have 100w as main beams, also living in jamaica at the moment and probably 30% of people are running 100w bulbs fine because there no laws like that
PUG1OFF Cat Cams/ ECU project
rubyspilot
PostPosted: Fri Nov 12, 2010 1:51 am Up
There's a bit of a clue on the packet when it says "off road use only"
Having said that the loom can handle it and plod would have to remove your bulbs to be sure.
But anything that attracts the attention of the "5-O" is not a good idea (think about any other crimes they might uncover) Cool Shocked
PostPosted: Fri Nov 12, 2010 6:14 am Up
Will the original relay be rated highly enough?
Rob2859
PostPosted: Fri Nov 12, 2010 6:17 am Up
I got my 100w ones because you can see the corners a lot further ahead on a dark 60 road which is very useful.
hobnob48
PostPosted: Fri Nov 12, 2010 7:17 am Up
My high beams are 100w Rally bulbs from hafords. To be honest you might as well just get the 100% or 150% brighter bulbs they sell as I checked the difference by having 1 in each side and they are not far off. Rally bulbs give a more yellow light then the others.
PS They havnt broken anything on my car yet and I do a lot of driving down dark roads Wink
Rob2859
PostPosted: Fri Nov 12, 2010 8:14 am Up
mind the ice and frost winter is coming. Or you will be posting a thread along the lines of "my car after a 50 foot drop" Laughing
hobnob48
PostPosted: Fri Nov 12, 2010 8:44 am Up
Dont you worry about me. I have an 05 plate astra. Easytronic and I have never known anything to go so well in the snow. It will get just about anywhere and handles pretty well Smile
My 206 is being used by a mate this winter lol
Rob2859
PostPosted: Fri Nov 12, 2010 9:25 am Up
I mean the odd ice patch hear and there. the electronic aids don't mean its impossible to crash.
I found my 206 is pretty good in the snow considering it doesn't have and fancy electronic stuff.
hobnob48
PostPosted: Fri Nov 12, 2010 9:43 am Up
Awsome. Also found mk3 fiestas are good too. So if anyone is looking for a cheap car so they dont damage their 206 in the weather try and find one of them
Page 2 of 2
