Online Now [209]:
Visitors: 208
Today: 22101
Total: 143090583
Forums › The Car › 206 Talk › 180 master cylinder - other MC's that will fit
EuroPeugeot
PostPosted: Fri Nov 12, 2010 10:59 am Up
From GTi 180 to GTi 138 - Its 100% different to the GTi 138's MC, due to traction control and different sized brake hoses.
Anybody know what car would share the same MC as the 180?
So I can go and buy one ASAP tomorrow hopefully..
Brian
PostPosted: Fri Nov 12, 2010 11:37 am Up
Trade Rating: +31
307 hdi also uses the 180's brakes. So that's worth a shout. There's a 307 that also shares the 180 engine.
T_bandery
PostPosted: Fri Nov 12, 2010 11:50 am Up
The 307cc 180bhp has the same engine as the 206gti 180 Smile
PostPosted: Fri Nov 12, 2010 12:12 pm Up
It's not 100% different to an ESP equipped 138 GTi...
EuroPeugeot
PostPosted: Fri Nov 12, 2010 12:45 pm Up
Any idea if ALL the 307's come with ESP?
T_bandery
PostPosted: Fri Nov 12, 2010 12:49 pm Up
The 307cc 180 has esp, not sure about the HDi though
Schumi
PostPosted: Fri Nov 12, 2010 1:01 pm Up
180 MC have a connector house for brake pressure sensor. I checked other 207-307-308 mc with ESP but i didnt see this connector. I checked this because i want bigger 23.8 mc for my brembos but i wanna keep esp working.
2005 206 RC RED
EuroPeugeot
PostPosted: Fri Nov 12, 2010 3:32 pm Up
Hmmm, but remembering that brake pressure hose is NOT actually connected to the MC istelf. Its connected to the reservoir. Therefore should be fine?
I also have brembos, and I wanted a bigger 23.8mm MC. But the esp sensor IS apart of the actual MC. Sooooo, we need to find a MC WITH an esp sensor connection, and to be 23.8mm..
Any ideas.. Haa
Schumi
PostPosted: Wed Nov 17, 2010 1:37 pm Up
I'm actual still searching. But i didnt find any peugeot MC with ESP sensor connection. I will try buy any 23.8 ABS MC. Drill and weld connection for ESP connection.
2005 206 RC RED
PostPosted: Wed Nov 17, 2010 2:10 pm Up
I have one of the late 04 Gti 138's, and i have ESP.
EuroPeugeot
PostPosted: Fri Nov 19, 2010 3:38 am Up
If you make this, PLEASE tell me if it works Smile I would be more than happy to pay you for this Very Happy
I know that some or most of the later GTi 138's have ESP, but we both want a bigger MC than even the GTi 180. Thanks anyway Smile
Schumi
PostPosted: Thu Dec 16, 2010 6:53 am Up
I didnt order 23.8 MC at the moment. I will order this month and drill it Very Happy
2005 206 RC RED
EuroPeugeot
PostPosted: Thu Dec 16, 2010 7:53 am Up
Sweet! Keep the thread updated Smile
PostPosted: Thu Dec 16, 2010 1:09 pm Up
Peugeot Sport do some 25.4 mm master cylinders...doesn't have fitting for all the road car nonsense but might be worth a look for some people.
EuroPeugeot
PostPosted: Thu Dec 23, 2010 7:45 am Up
How and where would I buy this?
Isit the normal shape Peugeot use? Basically would it go straight into my brake servo? Because if it does, then as above, it might be able to be modified to allow for a ESP connection..
