Latest: tbafonso
Overall: 17130
Online Now [339]:
Visitors: 338
Today: 70156
Total: 104259772
Forums › The Car › 206 Talk › 180 Alloy wheel tyre pressure?
PostPosted: Sat Nov 20, 2010 10:47 am Up
Hi guys, I got some 180 wheels on my car, not sure on the size tyres but i assume all tyres should be the same, what i'm wanting to find out is what the pressure should be?
Lecktorious
PostPosted: Sat Nov 20, 2010 10:56 am Up
Trade Rating: +59
Well if you have one Vortex with a 16" tyre fitted then your in trouble Laughing
Tyre pressures will be the same as before.
'98 Nile Blue 306 GTi 6
PostPosted: Sat Nov 20, 2010 11:00 am Up
there 17" tyres just don't know the offset whether there 40 or a 35 etc
Lecktorious
PostPosted: Sat Nov 20, 2010 11:02 am Up
Trade Rating: +59
Why would the tyres have an offset Confused
brad-morris
PostPosted: Sat Nov 20, 2010 11:05 am Up
The alloys have the offset PCD and all that. The tyres will be slightly diffrent depending on what youve put on i think its 32PSI ill double check though
brad-morris
PostPosted: Sat Nov 20, 2010 11:06 am Up
32 Front
30 Rear
Very Happy
PostPosted: Sat Nov 20, 2010 11:11 am Up
brad-morris wrote:
32 Front
30 Rear
Very Happy
Cheers Brad Very Happy
brad-morris
PostPosted: Sat Nov 20, 2010 11:50 am Up
No problem Smile
PostPosted: Sat Nov 20, 2010 4:48 pm Up
i run mine at 33psi all round thats what it says on my door pillar sticker thingy Smile
namgaj
PostPosted: Sat Nov 20, 2010 5:16 pm Up
Usually says on the tyre sidewall the Max PSI they can run, I usually go a few PSI under the max
4.0 V8 S-Type Jaguar
mattymj
PostPosted: Sat Nov 20, 2010 7:23 pm Up
I go 2.4 bar all round
data
PostPosted: Sun Nov 21, 2010 6:07 am Up
Mine says 2.2 bar whatever that is! I normally go with psi Smile
Onyx Black 2005 206 GTi 180, 44K miles, FSH, standard (apart from a K&N panel air filter, Angel Eyes and groovey rear & groovey front holy discs!)
PostPosted: Mon Nov 22, 2010 2:33 pm Up
Wall Bang
find your tyres always wear in the centre and have a really hard ride by any chance? Rolling Eyes
PostPosted: Mon Nov 22, 2010 3:16 pm Up
rttam wrote:
Wall Bang
not nessarily, it all depends on which tyre you got.
