Online Now [103]:
Visitors: 102
Today: 44257
Total: 138723262
Forums › The Car › 206 Talk › help and info about 206 please
Go to page Previous  1, 2
PostPosted: Sat Nov 20, 2010 2:20 pm Up
Corsa_Alex wrote:
okay cheers
so stay away from ngk plugs, can upset the coilpack which ive heard is quite common.
also the rear axle bit rubbish sometimes?
and also been told the thrust bearings can do quite easily so no riding the clutch ?
The rear axel bearings tend to take a beating if the car has been lowered. If its at standard height then it should be fine I reckon...
rubyspilot
PostPosted: Sat Nov 20, 2010 2:41 pm Up
So to conclude....French cars are great..... much the same as their planes (airbus) until they go wrong and then your f****d (recent qantas engine explosion)
continentalgt
PostPosted: Sat Nov 20, 2010 3:08 pm Up
I run an Astra and recently bought a 206 1.4hdi to use as a cheap runaround. No problems so far but the build quality is not as good as the Astra. Owner of the garage I use wasn't a fan of 206's and said they were OK until something goes wrong. Bit of a general statement but that was his opinion, I guess time will tell.
206 1.4hdi & 1.8 Astra Elegance
Page 2 of 2
