Latest: Kifi69
Overall: 17183
Online Now [312]:
Visitors: 311
Members: 1
Today: 28701
Total: 144175765
Forums › The Car › Solved 206 Problems › wiring gauges?
wiring gauges?
nakednakeddave
PostPosted: Thu Nov 25, 2010 2:46 pm Up
wheres the best place to wire a gauge from the dash to the battery?
where can i go through the bulkhead?
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
ExoVyper
PostPosted: Thu Nov 25, 2010 2:47 pm Up
are you wanting it to go off with the key or are you wiring a switch into it?
nakednakeddave
PostPosted: Thu Nov 25, 2010 2:51 pm Up
depends how easy it is to hook it to the ignition...
KRU KREW
ExoVyper
PostPosted: Thu Nov 25, 2010 2:53 pm Up
absolute piece of pi$$ mate you just remove the bottom cover from your steering column and it's there. you just need a multimeter to find which wire it is, a simple scotch lock later and your sorted pal
nakednakeddave
PostPosted: Thu Nov 25, 2010 2:55 pm Up
balls one thing i don't have is a multi meter....although i am hooking up the volt gauge...
KRU KREW
ExoVyper
PostPosted: Thu Nov 25, 2010 2:58 pm Up
even better!
easiest way to do it is grab a stanley knife and touch the volt meters wire to it then cut gently into it's either a yellow or a red wire i think... the stanley is an easy way without stabbing your fingers of getting the right wire Razz
remember to use the ignition though! i have gotten the wrong wire before only to find out after i put all the covers back on T_T
ExoVyper
PostPosted: Thu Nov 25, 2010 2:59 pm Up
but grab yourself a cheap multimeter as they are invaluable Smile
nakednakeddave
PostPosted: Thu Nov 25, 2010 3:00 pm Up
used to have one but it went walkies and never appeared...
but cheers for the help
Laughing
KRU KREW
ExoVyper
PostPosted: Thu Nov 25, 2010 3:24 pm Up
Laughing
i know that feeling Rolling Eyes was typical at my old work
no problem pal i'm always here to help when i can ^_^
