Latest: jackrox1992
Overall: 17186
Online Now [357]:
Visitors: 356
Today: 113788
Total: 148485951
Forums › The Car › 206 Talk › 206 1.4 HDI noise from fuel filter area?
Forum Index › 206 Talk
ChrisJH
PostPosted: Mon Nov 29, 2010 11:15 am Up
On pressing throttle I get a noise from the fuel filter area. Unsure if it's actually the filter. But changing it as a precaution hasn't fixed it. Happens at various revs and seems to be louder at higher rev ranges. Also occasionally happens when revs dropping back to idle when engine under no load. Anyone got any ideas or heard of this before?
CJH
Dan206
PostPosted: Mon Nov 29, 2010 11:21 am Up
Mine does exactly the same, getting it checked out this week. Will let you know what I get told, is yours a kind of rattley noise?
ChrisJH
PostPosted: Mon Nov 29, 2010 11:29 am Up
I suppose it could be described as "rattley", but kind of high pitched?
CJH
Dan206
PostPosted: Mon Nov 29, 2010 12:19 pm Up
Hmm mine is just a rattle really, wouldnt call it high pitched. Best to get it looked at mate
continentalgt
PostPosted: Mon Nov 29, 2010 3:36 pm Up
Check the black plastic top engine cover isn't vibrating by putting your hand on it at various points and revving the engine. It's only pushed on and the plastic lugs wear particularly the single one on the battery side of the engine.
ChrisJH
PostPosted: Tue Nov 30, 2010 1:57 am Up
No I've been under the bonnet with the engine cover off, & it's not that. It does sound more like a "popping/squeek" sound from the filter area.
CJH
ChrisJH
PostPosted: Tue Nov 30, 2010 10:19 am Up
Do you reckon it could be the duel mass flywheel failing? The car is a little "lumpy" when starting up.
CJH
PostPosted: Tue Nov 30, 2010 10:53 am Up
You don't have one
ChrisJH
PostPosted: Tue Nov 30, 2010 1:36 pm Up
Just had another good look around & noise seems to be coming from a "sensor" mounted to the bulkhead. Looks like a couple of thin vacuum pipes going to it. Anyone know what this is?
CJH
PostPosted: Tue Nov 30, 2010 1:37 pm Up
Pictures would help
And maybe a sound clip of the noise
