Latest: Kifi69
Overall: 17183
Online Now [258]:
Visitors: 257
Today: 26881
Total: 144654931
Forums › The Car › 206 Talk › Aftermarket Head Unit Help
Forum Index › 206 Talk
kal_1983uk
PostPosted: Thu Dec 02, 2010 9:43 am Up
Hi Guys,
I have just brought a JVC head unit for the Mrs car. She has 206, 2002 (52) plate.
I'm going to attempt and fit this myself. But what additional kit will I be needing?
I've been told I will only need the following:
1. Universal ISO to Din Antenna Aerial Adaptor
2. Autolead
Is this correct or am I missing something. I take it I shouldn't encounter any other problems when doing this?
Appreciate any help.
kal_1983uk
ukskater01
PostPosted: Thu Dec 02, 2010 10:30 am Up
It depends on the head unit but I think most jvc's need a autoleads to iso cable which should of came with the unit itself? You will also need the ariel adapter if needed like you said. Does your mrs want the stalk by the steering to work, if so you will need a patch lead and jvc cable for it I think, have a search for that
hope I've helped
cheers
copey
PostPosted: Thu Dec 02, 2010 11:12 am Up
also make sure if you want the stalk control working, that the head unit has the relevant feature
02 2.0 hdi d turbo
