Forums › The Car › 206 Talk › GTI 138 VS GTI 180 |
Posted: Sun Dec 05, 2010 4:12 am |
You wouldn't want to put throttle bodies on an 04 plate GTi...would have to change the pedal set up for one that can pull a cable as they come with motorised throttle body.
Posted: Sun Dec 05, 2010 5:01 am |
Pedal Conversion?
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Sun Dec 05, 2010 5:09 am |
Out of curiosity, how much are throttle bodies all in (inc fitting etc) and what sort of gains do you get? What power you pushing Edward?
Posted: Sun Dec 05, 2010 5:21 am |
Mattie-VTs wrote: |
Pedal Conversion? |
FBW the 180 are aposed to cable on 138
Posted: Sun Dec 05, 2010 5:39 am |
Posted: Sun Dec 05, 2010 6:14 am |
Lee. wrote: |
Out of curiosity, how much are throttle bodies all in (inc fitting etc) and what sort of gains do you get? What power you pushing Edward? |
Ecosse claimed the car is putting out 214bhp.
You can probably get TB's with a mainstream ECU (Omex, Emerald etc) fitted and mapped for about £2,500. I've put about £7k into mine with all the various new parts such as the exhaust and manifold, carbon airbox, cams, verniers, engine mounts, Longman head, hydraulic lifters and rewiring the car and all the wiring components required to do that.
kieron206gti wrote: |
FBW the 180 are aposed to cable on 138 |
Later 138's with traction control also have a FBW set up
Posted: Sun Dec 05, 2010 6:24 am |
So you've seen an increase of 76bhp? That's pretty good going! So what your saying is that the same parts in a 180 wouldn't have the same benefits?
Posted: Sun Dec 05, 2010 6:41 am |
You can fit the exact parts and the result would be the same...but you'd have spent more because the 180 costs more to start with.
Posted: Sun Dec 05, 2010 6:45 am |
But wouldn't the initial outlay of a couple of hundred quid (for a newer car) be worth it considering you'd have the colourcoding, interior etc?
Posted: Sun Dec 05, 2010 7:16 am |
Lee. wrote: |
But wouldn't the initial outlay of a couple of hundred quid (for a newer car) be worth it considering you'd have the colourcoding, interior etc? |
it depends on what are you going to do with your car
if is was a track car or rally car then...
Posted: Sun Dec 05, 2010 7:24 am |
Edward wrote: |
You can fit the exact parts and the result would be the same...but you'd have spent more because the 180 costs more to start with. |
Surely the extra few quid you'd spend on a 180 with all the extras over the 138 would pale into insignificance when compared to the £7000 you've spent on upgrades?
Posted: Sun Dec 05, 2010 7:33 am |
Edward wrote: |
Later 138's with traction control also have a FBW set up |
Would converting from FBW to Cable affect the ESP then?
Posted: Sun Dec 05, 2010 7:40 am |
Mattie-VTs wrote: |
Edward wrote: |
Would converting from FBW to Cable affect the ESP then? |
quote me if im wrong but im sure the ESP/TRACTION runs along the motorized throttle body so im guessing yes
from somthing i read when the wheels start to spin or loose grid it shuts the throttle down i may be wrong tho
Posted: Sun Dec 05, 2010 8:26 am |
Mattie-VTs wrote: |
Edward wrote: |
from somthing i read when the wheels start to spin or loose grid it shuts the throttle down i may be wrong tho |
This is what i need to know tbh,,
from experiance this week in the snow when the wheels spin the revs drop but not all the way then they splutter up and down,, i thought it may be ecu controling the rev limiter maybe.
Posted: Sun Dec 05, 2010 8:46 am |
