Latest: Beduff1977
Overall: 17134
Online Now [956]:
Visitors: 955
Today: 130068
Total: 107790240
Forums › The Car › 206 Talk › GTI 138 VS GTI 180
GTI 138 VS GTI 180
Go to page Previous  1, 2, 3 ... 10, 11, 12 ... 16, 17, 18  Next
Schumi
PostPosted: Sun Dec 05, 2010 11:18 am Up
ESP still work after converting wire to cable pedal conversion. But ASR didnt work.
2005 206 RC RED
|SGP|
PostPosted: Sun Dec 05, 2010 11:26 am Up
Yeah because everyone I know has put ITBs on thier cars, and the functionality of them is what makes and breaks the deal. Rolling On The Floor Laughing
View my car
PostPosted: Sun Dec 05, 2010 11:33 am Up
*Grabs pop corn*
Come on peoples, defend your beloved GTI Rolling On The Floor Laughing
Handbags at 12 paces though please
macj
PostPosted: Sun Dec 05, 2010 11:36 am Up
I do the T/B kit for £1550+vat with everything you need to fit stand-alone or piggy-back..... add another 1k for fitting and RR set-up
The reason I wouldnt do a 180 conversion for road use is the loss of the functions like VVT and all the driving cheats like traction control. If you want T/B conversion on a 180 keep it for trackdays and fast road use and I can junk the VVT.
To achieve the 76HP you would need to spend money like Edward. you will need the cams headwork and the exhaust. On the plus side you could fit 45mm T/B`s rather than the 42mm that Ed has chosen.
One thing is for sure... If you want good advise on this issue it pays to listen to the likes of him who have the experience in it
Lee.
PostPosted: Sun Dec 05, 2010 11:56 am Up
What I don't get though is this:
You've spent £7k on 70odd bhp. The 180 already has half of this as standard over the 138. So on that basis you should be prepared to spend £3.5k more on a 180?
(By the way this is no dig at you Edward, I have alot of respect for what you've done to your car, I'm just using your figures as a reference)
Mattie-RS
PostPosted: Sun Dec 05, 2010 12:00 pm Up
Whats ASR??
And is that a price for the GTi mac?? and using Jenvey??
macj
PostPosted: Sun Dec 05, 2010 12:03 pm Up
Mattie-VTs wrote:
Whats ASR??
Yes it is.... would give you about 180HP and 160ft/lb torque on standard cams, bit more with a de-cat
Mattie-RS
PostPosted: Sun Dec 05, 2010 12:06 pm Up
macj wrote:
Mattie-VTs wrote:
Whats ASR??
What are prices for a 1.6 16v Engine Razz
And is it everything you need to get going minus the ECU??
macj
PostPosted: Sun Dec 05, 2010 12:08 pm Up
That price included the ECU.... identical to the rally car
The Newman cams are a good buy on here.... see the post
www.206info.co.uk/Foru...20060.html
Antix
PostPosted: Sun Dec 05, 2010 12:37 pm Up
Custom - Red Stars
Mattie-VTs wrote:
Whats ASR??
ASR is the anti-skid function
ESP is electronic stability programme function (which also activates the hazard lights automatically)
PostPosted: Sun Dec 05, 2010 12:44 pm Up
I'm not quite sure what you are saying but as a standard car if I only wanted 180 bhp then I would buy the 180 (when I got my 138 the 180 had only just been launched).
But if I knew I wanted to end up with over 200bhp I'd start with the 138. No point paying for all the GTi 180 extras when they'll just be thrown away.
But then if you also wanted to buy a 138 and tune it to GTi 180 power levels then that would be more interesting to own than a GTi 180.
Mattie-RS
PostPosted: Sun Dec 05, 2010 12:50 pm Up
Antix wrote:
Mattie-VTs wrote:
Whats ASR??
How would changine to cable effect anti skid fucntion tho Confused
PostPosted: Sun Dec 05, 2010 1:06 pm Up
Mattie-VTs wrote:
Antix wrote:
Mattie-VTs wrote:
Whats ASR??
The traction control system used on the 206 needs a fly by wire throttle to work.
Mattie-RS
PostPosted: Sun Dec 05, 2010 1:12 pm Up
MrBSI wrote:
Mattie-VTs wrote:
Antix wrote:
Mattie-VTs wrote:
Whats ASR??
I dont own a 206 Razz Wonder if the C2 is the same tho :/
PostPosted: Sun Dec 05, 2010 1:14 pm Up
Mattie-VTs wrote:
MrBSI wrote:
Mattie-VTs wrote:
Antix wrote:
Mattie-VTs wrote:
Whats ASR??
Have a look, its a good bet it is seeing as its all the same PSA parts bin engineering Laughing
Page 11 of 18
