Latest: tbafonso
Overall: 17130
Online Now [104]:
Visitors: 103
Today: 3616
Total: 103865808
Forums › The Car › 206 Problems › rear wiper, and auto wiper
mjsroofing
PostPosted: Sun Dec 05, 2010 1:31 pm Up
hi again, the rear wiper is strange some times it wipes just the once some times two or three times is this any thing to do with the auto wipers. oh and i find the auto wipe is a little sensitive to the rain can this be adjusted
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
mjsroofing
PostPosted: Sat Dec 11, 2010 3:22 am Up
any one
Mark
continentalgt
PostPosted: Sat Dec 11, 2010 6:48 am Up
I got the same problem with the rear wiper, seems to be worst when it's cold out. Wipes 2 or 3 times then parks in the straight up position then it works OK after a few miles. Last week when it was freezing it wiped 30 or 40 times before parking. I can hear the relay switching on and off so I'm gonna try rebooting the BSI when I get the chance.
206 1.4hdi & 1.8 Astra Elegance
mjsroofing
PostPosted: Sat Dec 11, 2010 1:53 pm Up
yep thats it, mine is the same, how do you reboot it then
Mark
mjsroofing
PostPosted: Sun Dec 12, 2010 2:27 pm Up
i know how to reboot now
Mark
paulrushton
PostPosted: Thu Jan 20, 2011 2:12 pm Up
Did this ever get solved?? I've got the same problem.
Peugeot 206 GTI HDI Black
PostPosted: Thu Jan 20, 2011 2:14 pm Up
Does it only wipe once when reverse gear is selected?
paulrushton
PostPosted: Thu Jan 20, 2011 2:31 pm Up
Mine randomly stops half sweep and rarely parks where it should. It can wipe anywhere between 1-3 times typically but sometimes goes on and on for ages. Also recently noticed when I unlock it on the fob it will sweep a few times then as well! I had this on a previous Citroen C4 and it was a split in the wiring loom where it enters the boot. I'll check there but wondered if it was a common issue/easy fix.
