Latest: Stu-mill
Overall: 17131
Online Now [105]:
Visitors: 104
Today: 3346
Total: 104913016
Forums › The Car › 206 Problems › Windscreen Washers not working
206driver
PostPosted: Mon Dec 06, 2010 1:44 pm Up
Evening people,
My windscreen wipers have stopped working! Now you will probably say its due to the low or FREEZING temperatures but surely I should still be able to hear the whiney noise when I pull back the leaver to activate the water flow???
If it turns out that a fuse has gone, where will this be located? e.g. driver side or bonnet?
I'm sure this stuff has been mentioned on this website but I am not a big fan of the search function!
Any help advice will be appriciated!
Peugeot 206 1.9D LX 2000 0-60... 10 minutes!
PostPosted: Mon Dec 06, 2010 1:51 pm Up
Fuse 25 in drivers fuse box
Does the rear wiper work?
If not, then it could be the stalk that is faulty if the fuse is ok
206driver
PostPosted: Mon Dec 06, 2010 1:57 pm Up
Hmm both front and rear wipers work fine, its just the water that doesnt!
PostPosted: Mon Dec 06, 2010 1:59 pm Up
Your opening post say they don't work Laughing
Probably just froze up
brad-morris
youll be hard pushed getting the water working in this weather my 206 or my caddy van wont spray any
206driver
PostPosted: Mon Dec 06, 2010 2:03 pm Up
Dam! i got loads of s**t on the windscreen! I'll just wait and see what happens!
brad-morris
PostPosted: Mon Dec 06, 2010 2:05 pm Up
hahaa clean it off when you get home Smile but itll only happen again within 10 miless on the motorway Laughing
Daza
PostPosted: Mon Dec 06, 2010 2:30 pm Up
Mine did this today! it was a blown fuse (10 amp) under the steering wheel. easy fix Smile
PostPosted: Mon Dec 06, 2010 3:24 pm Up
So in fact its your washers, not your wipers?
206driver
PostPosted: Mon Dec 06, 2010 4:25 pm Up
Yep!
matcarlin24
PostPosted: Wed Dec 08, 2010 6:52 am Up
yoo i got same problem but i checked fuse and its ok there is just no noise when i pull the lever back :/
206 Moonstone 1.4 8v Wink
matcarlin24
PostPosted: Wed Dec 08, 2010 6:58 am Up
206driver you fixed it yet ?
MarkHDi
PostPosted: Wed Dec 08, 2010 7:14 am Up
Mine did this, exact same symptoms of no noise or blown fuse but wipers worked fine. Started working yesterday in the end now the temps have started warming up a bit so I'd guess its just a frozen washer bottle. I've since drained and filled with proper screen wash as the stuff that was in there was likely to be just water after the times I topped it up from the hose Razz
Owner of a tatty HDi, really must neaten it up!
rob_1990
PostPosted: Wed Dec 08, 2010 7:27 am Up
Its the water in the pump that has frozen, thus it wont make a noise because the motor cannot turn...
S4M106
PostPosted: Wed Dec 08, 2010 8:49 am Up
We are having alot of cars come in at the moment with the same problem its normally down to the screenwash in the resivoir tank being frozen think when you going along we have taken readings of cars temps going down to -20degrees stupid, i wouldnt worry about it Smile
