Posted: Mon Dec 06, 2010 1:44 pm |
Evening people,
My windscreen wipers have stopped working! Now you will probably say its due to the low or FREEZING temperatures but surely I should still be able to hear the whiney noise when I pull back the leaver to activate the water flow???
If it turns out that a fuse has gone, where will this be located? e.g. driver side or bonnet?
I'm sure this stuff has been mentioned on this website but I am not a big fan of the search function!
Any help advice will be appriciated!
| Peugeot 206 1.9D LX 2000 0-60... 10 minutes! | |
Posted: Mon Dec 06, 2010 1:51 pm |
Fuse 25 in drivers fuse box
Does the rear wiper work?
If not, then it could be the stalk that is faulty if the fuse is ok
Posted: Mon Dec 06, 2010 1:57 pm |
Hmm both front and rear wipers work fine, its just the water that doesnt!
Posted: Mon Dec 06, 2010 1:59 pm |
Your opening post say they don't work
Probably just froze up
youll be hard pushed getting the water working in this weather my 206 or my caddy van wont spray any
Posted: Mon Dec 06, 2010 2:03 pm |
Dam! i got loads of s**t on the windscreen! I'll just wait and see what happens!
Posted: Mon Dec 06, 2010 2:05 pm |
206driver wrote: |
Dam! i got loads of s**t on the windscreen! I'll just wait and see what happens! |
hahaa clean it off when you get home but itll only happen again within 10 miless on the motorway
Posted: Mon Dec 06, 2010 2:30 pm |
Mine did this today! it was a blown fuse (10 amp) under the steering wheel. easy fix
Posted: Mon Dec 06, 2010 3:24 pm |
So in fact its your washers, not your wipers?
Posted: Mon Dec 06, 2010 4:25 pm |
Yep!
Posted: Wed Dec 08, 2010 6:52 am |
yoo i got same problem but i checked fuse and its ok there is just no noise when i pull the lever back :/
Posted: Wed Dec 08, 2010 6:58 am |
206driver you fixed it yet ?
Posted: Wed Dec 08, 2010 7:14 am |
Mine did this, exact same symptoms of no noise or blown fuse but wipers worked fine. Started working yesterday in the end now the temps have started warming up a bit so I'd guess its just a frozen washer bottle. I've since drained and filled with proper screen wash as the stuff that was in there was likely to be just water after the times I topped it up from the hose
| Owner of a tatty HDi, really must neaten it up! | |
Posted: Wed Dec 08, 2010 7:27 am |
Its the water in the pump that has frozen, thus it wont make a noise because the motor cannot turn...
Posted: Wed Dec 08, 2010 8:49 am |
We are having alot of cars come in at the moment with the same problem its normally down to the screenwash in the resivoir tank being frozen think when you going along we have taken readings of cars temps going down to -20degrees stupid, i wouldnt worry about it
