Online Now [551]:
Visitors: 550
Today: 80
Total: 105577086
Forums › The Car › 206 Problems › electrical issues - possibly bad earth?
copey
PostPosted: Fri Nov 05, 2010 7:30 am Up
basically im having a few issue with my car, when i flash my lights my stereo will cut out, when i wind my window up to top, the abs light flashes, and mfd dims....when i indicate the mfd flashes in time with the indicators...when i start the car the doors lock them selves ~(it hasnt got auto locking on there)
just wondering if this could be a bad earth problem, and if it is.....where would i start lookin for the possible earths
02 2.0 hdi d turbo
panason1c
PostPosted: Fri Nov 05, 2010 7:53 am Up
try a bsi reset.......
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Rob2859
PostPosted: Fri Nov 05, 2010 9:07 am Up
when i operate my windows my interior light goes dim. when i press my horn (air horn mind) the headlights go dim. not sure if these are problems as such
Danw_VVT
PostPosted: Fri Nov 05, 2010 9:11 am Up
the headlights radio etc run off the same circuit so if you have somethin (air horn) that draws more power then standard one it will take the power from else where in this case the lights etc.
copey
PostPosted: Fri Nov 05, 2010 9:50 am Up
so am i right in thinking that they all would use the same earth with it?
and already tried the bsi softboot to no avail
02 2.0 hdi d turbo
PostPosted: Fri Nov 05, 2010 10:05 am Up
just follow the earth straps from the batt to the chassis.
copey
PostPosted: Fri Nov 05, 2010 10:18 am Up
are they the only earths for the dash and windows ect?...i havent a clue when it comes to wiring.
02 2.0 hdi d turbo
copey
PostPosted: Sun Nov 07, 2010 6:36 am Up
where abouts do the earths run off the battery?
02 2.0 hdi d turbo
PostPosted: Sun Nov 07, 2010 7:42 am Up
Go to batt, follow the earth cables from the - side of the batt. They dont go far.
copey
PostPosted: Sun Nov 07, 2010 8:51 am Up
cool will have a gander shortly, im hoping to spot something looking a miss, if not....its back to the drawing board
02 2.0 hdi d turbo
Rob2859
PostPosted: Mon Nov 08, 2010 7:11 pm Up
My headlights dim when i press the brakes too. other stuff does it too but i can't remember what. Still think this is normal?
Sorry to thread jack btw Smile
copey
PostPosted: Wed Nov 10, 2010 1:07 pm Up
well i think ive fixed the problem, zero issues since the weekend...the bolt on the fuse box under the engine, with the live connected to it, had become a little loose, only a couple of turns so tightened it up, and everything has been good since, so hopin thats the last of it
02 2.0 hdi d turbo
actionman
PostPosted: Wed Dec 08, 2010 11:35 am Up
fuse box under the engine??? Confused
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
copey
PostPosted: Wed Dec 08, 2010 11:38 am Up
under the bonnet,
02 2.0 hdi d turbo
actionman
PostPosted: Wed Dec 08, 2010 11:41 am Up
yeh that's that's what you meant!! needed to make sure though!! Wink
