Latest: Puggingalong
Overall: 17129
Online Now [108]:
Visitors: 107
Today: 50745
Total: 101175511
Forums › The Car › 206 Talk › what engine is this from?
Go to page Previous  1, 2
PostPosted: Thu Dec 09, 2010 6:41 am Up
Very Happy
greenpug2222
PostPosted: Fri Dec 10, 2010 3:20 am Up
tomd0801754................ no idea, But not sure how i would know or check????????????????
Rob2859........................ Ill try and have a look very soon.
Is there a way to look up engine numbers online???
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Fri Dec 10, 2010 3:24 am Up
wikipedia has the engine numbers for peugeot, citreon etc....
greenpug2222
PostPosted: Fri Dec 10, 2010 4:04 am Up
rearly???? do i just wack my number in the search?
PostPosted: Fri Dec 10, 2010 4:15 am Up
im not sure what you mean by looking up engine numbers.
the engines used inthe 206 are on the right
en.wikipedia.org/wiki/Peugeot_206
PostPosted: Fri Dec 10, 2010 1:04 pm Up
The engine will be a TU3JP or a TU3A
The engine number is on the left hand side of the cylinder block. The first three numbers will be the engine code, and it should be the same as the 6th, 7th and 8th letters of your VIN number.
PostPosted: Fri Dec 10, 2010 1:24 pm Up
just because it was originally a 1.4 someone could of put a 1.6 tu lump in check the engine number located where lee says Smile
greenpug2222
PostPosted: Mon Dec 13, 2010 7:12 am Up
Having problems seeing where i need to look, The isnt much room to look around these TU engines in a 206..... My old XU lump in the 205 had loads of room to see things.
Any pics to show me the right way would be appreciated?
Page 2 of 2
