Online Now [229]:
Visitors: 228
Today: 47299
Total: 143173767
Forums › The Car › Solved 206 Problems › Fault code P1160??
Fault code P1160??
neil35
PostPosted: Sun Dec 12, 2010 11:42 am Up
I have started to have problems with my 206 (2005) 1.4HDI. When i accellarate above normal the engine light comes on and using my reader I get the code P1160 (and power loss).. If i reset the light using reader everything works ok until i accellerate above normal and it comes on again.. When i rev the engine hard whilst stationary i get no engine light but a very sooty driveway..
Please help as im lost as that code is not on any lists that i have..
Thanks ,, Neil
PostPosted: Sun Dec 12, 2010 11:50 am Up
P1160 = Manifold Temp.Sensor Circuit. Short to Ground
Bigbenj_08
PostPosted: Sun Dec 12, 2010 11:53 am Up
Just done a google search and this is all that comes back - for a 307cc - no idea if fault codes on pugs are the same across the range though.
www.peugeotforums.com/...php?t=7967
P1160 - intake manifold
Aegean Blue 1.6 16v Sport
neil35
wow. That is a quick reply. Is it genarally a sensor change?
Thankyou for that!!
Thanks ,, Neil
PostPosted: Sun Dec 12, 2010 11:55 am Up
Could be the sensor, it could also be the wiring.
The fault code just tells you where to start looking under the bonnet Wink
neil35
PostPosted: Sun Dec 12, 2010 2:44 pm Up
Think we have solved the problem.. Air filter was found to be split but i had a spare one so replaced it. Due to the soot around the split i took off the air flow meter and it was very black. Cleaned with contact cleaner and reset the ecu with my laptop. Cant get the fault to re-occur.so fingers crossed..
thanks to all
troy
PostPosted: Sun Dec 12, 2010 2:56 pm Up
how did you plug your laptop to the car?
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
neil35
PostPosted: Sun Dec 12, 2010 3:46 pm Up
used an elm 323 connector obd2 and scantool.net free software.elm 323 from ebay. About £30
Thanks ,, Neil
neil35
PostPosted: Tue Dec 14, 2010 5:18 pm Up
still working fine. how do i post this to solved ?? Very Happy
PostPosted: Tue Dec 14, 2010 5:20 pm Up
admin will do this when they saw it
