Online Now [1037]:
Visitors: 1036
Today: 64877
Total: 143263040
Forums › The Car › 206 Talk › camber on a 206
camber on a 206
europug
PostPosted: Tue Dec 14, 2010 9:48 am Up
was wondering if u could get camber shims for 206 as i was told on rear torsion bar u cannot get camber??
can anyone shed any light on this for me
Big_Rich180
PostPosted: Tue Dec 14, 2010 9:49 am Up
I have never seen any for them, you are right though the camber cannot be altered on the rear.
PostPosted: Tue Dec 14, 2010 9:50 am Up
It can be done, but it depends on how much money and axles you want to lob at it to get camber
europug
PostPosted: Tue Dec 14, 2010 10:22 am Up
fair enought not an easy job then
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:24 am Up
How do you do it then?? When i've had the wheels and everything off the stub pin and arm are solid, so how do you change the camber?
I ask out of intrest.
Ape
PostPosted: Tue Dec 14, 2010 10:30 am Up
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:48 am Up
Ape wrote:
Rolling On The Floor Laughing
Rob2859
PostPosted: Tue Dec 14, 2010 10:57 am Up
How about caster?
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:59 am Up
Rob2859 wrote:
How about caster?
Im sure you cant adjust anything on the rear, its all set solid.
The only thing i could think of to change the camber/caster is to bend the stub pin, but that seems stupid to me.
Rob2859
PostPosted: Tue Dec 14, 2010 11:02 am Up
Big_Rich180 wrote:
Rob2859 wrote:
How about caster?
I was refering to the front so it gives the steering more weight and feel
Ape
PostPosted: Tue Dec 14, 2010 11:04 am Up
Rob2859 wrote:
Big_Rich180 wrote:
Rob2859 wrote:
How about caster?
Rob, I've just read your sig. It's true!! I got home in record time on Monday Morning after leaving on Tuesday!!
Rob2859
PostPosted: Tue Dec 14, 2010 11:10 am Up
Ape wrote:
Rob2859 wrote:
Big_Rich180 wrote:
Rob2859 wrote:
How about caster?
useful consumer advice there Rolling On The Floor Laughing
PostPosted: Tue Dec 14, 2010 11:15 am Up
You would have to redesign the entire rear arms, one could be they are twisted but that may not be safe
Another could be machining out the rear stub so it has camber in the arms
Big_Rich180
PostPosted: Tue Dec 14, 2010 11:19 am Up
But then the bearings and stuff wouldnt fit on properly would they?
Sounds very dodgy to me either way, id leave it alone.
PostPosted: Tue Dec 14, 2010 11:25 am Up
Mate, i aint done it and frankly i aint trying it
Hence why i say YOU NEED A LOT OF MONEY, custom arms and bearings would be needed, not a simple case of machining out Rolling Eyes
