Latest: tbafonso
Overall: 17130
Online Now [612]:
Visitors: 612
Today: 22079
Total: 103066879
Forums › The Car › 206 Problems › still in limp mode
still in limp mode
rockerted
PostPosted: Thu Dec 16, 2010 5:02 am Up
just continuing the saga, had the 206 1.4hdi into pugs,found heater plug relay fault, fixed and a clutch switch, had maf checked, ok.been into a real expert,checked numerous things, to no avail!!now going to check the ecu!!so far £240 spent and still in limp mode..one thing certain, it,s the last pug we ever buy!!
rubber side down,please
Big_Rich180
PostPosted: Thu Dec 16, 2010 5:04 am Up
[quote="rockerted"]just continuing the saga, had the 206 1.4hdi into pugs,found heater plug relay fault, fixed and a clutch switch, had maf checked, ok.been into a real expert,checked numerous things, to no avail!!now going to check the ecu!!so far £240 spent and still in limp mode..one thing certain, it,s the last pug we ever buy!![/quote]
Ive lost count how many times ive said that Laughing
qwert
PostPosted: Thu Dec 16, 2010 6:07 am Up
have you had it scanned? Or are you just replacing parts for the fun of it?
brum brum
rockerted
PostPosted: Sat Dec 18, 2010 4:59 am Up
hi qwert, yes, diagnostic by peugeot, also by a tuners in sunderland,so checking bit by bit,next is ecu,not showing anything on diag,..ted
nelson
PostPosted: Sun Mar 13, 2011 3:45 pm Up
Trade Rating: -1
I'm using mine with the MAF disconnected... it uses more fuel and does not get all the power back but it is better than nothing
206 1.4Hdi =~91bhp
Upgrades: FMIC, decat, Eibach sport springs, Bilstein dampers, 21mm torsion bars, 22mm ARB, Sachs Performance uprated clutch, chiptuning
