Latest: Stu-mill
Overall: 17131
Online Now [69]:
Visitors: 68
Today: 8217
Total: 104917852
Forums › The Car › 206 Talk › Uprating Brakes.
Uprating Brakes.
PostPosted: Thu Dec 16, 2010 8:22 am Up
Ok, so with more power comes more responsibilty.. for the brakes.
I am presuming that the 2.0hdi brakes are a lesser standard than the 138/180 brakes?
If I was wanting to uprate them.. What is needed? I.e can I just swap the calipers over and get new, bigger, discs?
If this is correct, what about the ABS that I don't have but they do? Does it matter?
PostPosted: Thu Dec 16, 2010 8:26 am Up
same calipers as gti, which runs 266 disc,
180 run 283 disc.
do a search, this has been cover thousands time within last month lol
all 206 run the same size of mc.
if you want bigger brakes you can just swap the calipers+pad+disc.
but to be fair 266 disc is good as long as you put in some decent pad.
you got disc or drum at the back?
Mrs_Howey
i uprated my brakes and i don't have abs not the end of the world if you don't have it.
But it was mentioned to me after that i should have gotten the gti brake master cylinder as well other wise, your still running the same mc with the uprated brakes so might be worth changing that as well, but other wise the new calipers will just bolt on Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Thu Dec 16, 2010 8:43 am Up
180 run 283 disc.
Cheers. I was thinking of getting hold of some 180 calipers and putting a decent set of pads and discs on.
Drum on the rear. Sad Why?
Cheers GG. However what I meant about ABS is whether I need calipers from a non-ABS due to conections etc. Smile I'm guessing it doesn't matter Wink
PostPosted: Thu Dec 16, 2010 8:53 am Up
tomd0801754 wrote:
180 run 283 disc.
bigger and better brake at the front=increasing front bias, under hard braking, since there is not enough rear bias, the front had to take more workload(tyre skid)
and there is no easy way to upgrade rear drum
if you don't have ABS then you can use what ever you like. Cool
EuroPeugeot
PostPosted: Thu Dec 16, 2010 8:54 am Up
Ive got my old 180 calipers for sale Smile
I have brembos.
PM me if you want them
T_bandery
PostPosted: Thu Dec 16, 2010 8:57 am Up
Get some brembos from 406 v6, i saved up for them and never looked back Cool
PostPosted: Thu Dec 16, 2010 8:58 am Up
Seabook wrote:
tomd0801754 wrote:
180 run 283 disc.
So effectively your saying that I need to also upgrade to rear discs? Smile
PostPosted: Thu Dec 16, 2010 9:05 am Up
tomd0801754 wrote:
Seabook wrote:
tomd0801754 wrote:
180 run 283 disc.
it depends on what you want to do really. if just for standard road use apart from making you feeling better than the others it does nothing more Laughing
you can either live with it and be more careful when you brake; get some upgrade drum shoe; or get a disc axle and put on some better pad.
and it also down to what tyre and front pad you use as well.
Mattie-RS
PostPosted: Thu Dec 16, 2010 9:08 am Up
ABS isnt actually on the caliper Wink
I also have some C4 VTS calipers that run bigger discs than the 180 calipers Wink
That i can sell just to you Tom Razz
And are a straight fit as they where on my 206 1.6T Razz
303mm discs aswell compared to 287 or whatever 180's are
I would quote but its getting stupidly long! Wink
So: With the FMIC, map + poss FP and Injector upgrades... I don't feel that my brakes will like me very much. Hence me trying to sort this out in advance. Wink I've noticed recently that under heavy breaking the car doesn't feel stable, this is due to pads and discs being a bit... sh*t. Hence my thinking about this now, rather than replacing them then having to replace them again.
I need new tyres shortly anyway. So they shall be getting upgraded as well.
So, what do you feel I should do? Wink
Mattie-RS
PostPosted: Thu Dec 16, 2010 9:13 am Up
Buy mine Wink
PostPosted: Thu Dec 16, 2010 9:14 am Up
you don't need FP and injectors upgrade without a bigger turbo. i learn this in a hard way.
a good way to test if you brake is good enough is whether you can lock the brake up in dry tarmac. if you can, that means you don't need better brake, all you need is better tyre!
Spanerman
PostPosted: Thu Dec 16, 2010 9:20 am Up
Upgrading your brakes is more to deal with brake fade rather than braking force.
Put a 180 engine in a 1.1 shell with standard brakes, i bet you i could lock them up..... Once.
The bigger brakes have more area to disapate heat so a lot better at repetitive hard breaking
Hello
PostPosted: Thu Dec 16, 2010 9:31 am Up
that's why i am asking what he is going to do with his car lol
if you got brake fade on normal road, you should check your driving style.
if you got brake fade on track, 9 out of 10 is your got the wrong pad. your example is just too extreme.
