Online Now [480]:
Visitors: 479
Today: 28623
Total: 106222849
Forums › The Car › 206 Problems › abs esp asr not working?
kieron
PostPosted: Thu Dec 16, 2010 11:26 am Up
about 3 days ago i had a abs fault on my dash come up couple seconds later i had ESP/ASR fault so said to myself ill get that sorted out asap the next day its fine for a few hours then all of a sudden it will come back
its been on and off now for a few days just wanted to know is the asr/esp related to the abs fault or could i have 2 faults?
as its working somtimes and then it is not could the sensors on the hubs just be clogged up ?
any info would be great
cheers kieron
Account suspended
troy
PostPosted: Thu Dec 16, 2010 11:31 am Up
mine does this with just the abs light as i only have abs, my n/s front abs ring is cracked so it randomly birings up a fault every once in a wile. if you can afford a diagnostic check then i would jack the car up and check both front abs rings for cracks as they are very common to break.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
kieron
PostPosted: Thu Dec 16, 2010 11:34 am Up
i can get it diagnostic checked yes
would the cracks stand out i had a quick look at the rings the other day and to be fair the all seems fine
the light will sometimes be on from start up and other times it will be fine
Account suspended
troy
PostPosted: Thu Dec 16, 2010 11:38 am Up
ye, it would be a full crack all the way through the abs ring, if theyre not broken then your only bet is to get it plug into a diagnosis machine.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
panason1c
PostPosted: Thu Dec 16, 2010 11:44 am Up
Try giving the rings and sensors a good clean-up first.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
gti180boy
PostPosted: Fri Dec 17, 2010 3:55 pm Up
cheers kieron
Kieron why you all ways post on here before asking me to have a look at it lol Smile come down monday and i put on diag and see whats going on.
kyle
180 Doctor
kieron
PostPosted: Fri Dec 17, 2010 3:58 pm Up
because im not a retard Smile only joking
Account suspended
gti180boy
PostPosted: Fri Dec 17, 2010 4:08 pm Up
haha d.i.c.k
you going to bring it done to me on monday dude.
180 Doctor
kieron
PostPosted: Fri Dec 17, 2010 4:12 pm Up
gti180boy wrote:
haha d.i.c.k
yes can do if you dont mind..............
Account suspended
gti180boy
PostPosted: Fri Dec 17, 2010 4:18 pm Up
kieron206gti wrote:
gti180boy wrote:
haha d.i.c.k
No dont mind whats bro's for Smile
180 Doctor
