Online Now [365]:
Visitors: 364
Today: 60120
Total: 105323393
Forums › The Car › 206 Problems › car reading 5mph when at stop
Go to page 1, 2, 3  Next
troy
PostPosted: Thu Dec 16, 2010 2:31 pm Up
the other day i turned my ignition on and the speedo jumped to about 30mph and ever since it has sat at5mph, also the handbrake warning beep comes on when you put it up when stationary which is obviously related.
i also drove about 50 miles the other day and when i got to my destination the milage has only gone up 2miles on the trip and on the milage.
just incase it matters my n/s front abs ring is cracked and the light has been on for a while but i shouldnt have thought this would have affected the speedo when standing.
any ideas as the diagnostic brings up nothing
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
PostPosted: Thu Dec 16, 2010 2:39 pm Up
Cluster is f****d i would say
Iain
PostPosted: Thu Dec 16, 2010 2:41 pm Up
I thought some 206's (I don't remember which) used the ABS sensor as the input for your speedo? Either way it should be fixed as soon as possible really, so you'll find out if that was the issue.
If I'm wrong, which I probably am, I think there's a sensor on/attached/whatever to the gearbox. Could check the soldering behind the cluster as well (Basically what Lee said).
Have you tried searching? I'm pretty sure there's been similar problems.
Our snow > Your snow
troy
PostPosted: Thu Dec 16, 2010 5:33 pm Up
ye, i have searched but couldnt find anything. im goin to have a quick look at the cluster tommoorow.
strange thing is when you turn the ignition completely off the speed doesnt go down to zero, but i have disconected the battery and that drops it down to 0, but as soon as you reconect and put the ignition on it comes back to 5mph.
verry strange
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
panason1c
PostPosted: Fri Dec 17, 2010 2:28 am Up
Try a full bsi reset (do a search for details)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
troy
PostPosted: Fri Dec 17, 2010 7:25 am Up
iv done a search, has anyone got a link for the bsi reset, cant seem to find it anywhere
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
panason1c
PostPosted: Fri Dec 17, 2010 7:30 am Up
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
BMW K1200RS
troy
PostPosted: Fri Dec 17, 2010 7:31 am Up
lifesaver, il try that in a minute, just drove round now and my airbag light came on, switched car off then on and it was off.
these french things are s**te arnt they.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
mjsroofing
PostPosted: Fri Dec 17, 2010 7:32 am Up
open drivers window and bonnet. start engine, turn engine off, remove key, get out of car and close door. leave the car alone for 5 mins dont open a door or any thing, disconnect the battery, leave for 5 mins, dont touch ant thing. reconnect battery, put your arm through window and turn on side lights, you will hear a dong then start engine.
you beat me to it
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Fri Dec 17, 2010 7:33 am Up
It's non-plexed. So just d/c the battery will do it.
troy
PostPosted: Fri Dec 17, 2010 7:36 am Up
no its plexed, 04 plate buddy.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Fri Dec 17, 2010 7:38 am Up
ahh, thought it looked like a w-reg on the avatar Laughing
troy
PostPosted: Fri Dec 17, 2010 7:39 am Up
right, im gonna clean off the snow and give it a blast. will let you know how it turns out shortly
thanks
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
mjsroofing
PostPosted: Fri Dec 17, 2010 7:42 am Up
good luck wrap up its cold out there!!!!!!
Mark
troy
PostPosted: Fri Dec 17, 2010 8:30 am Up
i didnt hear a dong, is this normal, everything is exactly the same as before. if it didnt dong i take it that it needs doing again is it?
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
Page 1 of 3
