Posted: Fri Dec 17, 2010 5:48 am |
can someone please advise me on the following ![Smile Smile](images/smiles/icon_smile.gif)
is the gti 206 cable clutch?
if so will the clutch pedal and cable be the same as that for a 1.4 8v?
also will the gearlinkage from the stick to the subframe bit be the same?
i think the gearlinkages from the subframe bit to the box will be different to that of a 1.4 wont it?
are auto and manual starter motors the same on the tu engine?
will my engine run if i fit a manual box and unplug the gearbox ecu or will it affect the engine one?
reason is im converting my auto 206 to manual after the auto box went bang and trying to work out sourcing the right parts
i have found a gearbox off a mate and realise i will need a 1.4 flywheel, clutch and cranksensor can anyone else think of other stuff i need?
sorry for the million questions any help would be greatly apprecaited ![Smile Smile](images/smiles/icon_smile.gif)
thanks
matt
| | ![](images/spacer.gif) |
Posted: Fri Dec 17, 2010 5:53 am |
rttam wrote: |
thanks
matt |
I can answer that one for sure. No they are toally different in length. The GTi & 2.0 HDi share the same linkages for future reference.
Posted: Fri Dec 17, 2010 6:07 am |
Starter motors will be the same.
Dont forget to inform DVLA and your insurance company after the conversion.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Fri Dec 17, 2010 6:10 am |
cheers guys ![Smile Smile](images/smiles/icon_smile.gif)
yeah they will both be informed ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Fri Dec 17, 2010 6:13 am |
I've got a feeling it's gonna be one of those jobs you wished you never started........... )-:
BMW K1200RS | |
Posted: Fri Dec 17, 2010 6:17 am |
panason1c wrote: |
I've got a feeling it's gonna be one of those jobs you wished you never started........... )-: |
probably
im a mechanic by trade and have access to all the ramps and equipment at weekends so that isnt a problem although if a cheap accident damaged/mot failure/blown engine 206 comes up i may just buy that and swap all my bits over but cant find anything for less than a grand near me ![Crying or Very sad Crying or Very sad](images/smiles/icon_cry.gif)
Posted: Fri Dec 17, 2010 6:25 am |
In the early days, a conversion from auto to manual was a fairly straighforward job, but with the intervention of electronically controlled auto-gearbox's and, in some cases its ecu linked to the engine ecu, it is much more a complex conversion with a few 'unknowns' likely to be thrown into the equation.
BMW K1200RS | |
Posted: Fri Dec 17, 2010 9:23 am |
rttam wrote: |
is the gti 206 cable clutch? gti has no cable its hydraulic
Uses a different pedal to connect to slave cylinder
They are different
matt |
Posted: Fri Dec 17, 2010 10:15 am |
think this could be a no go then best start looking for a cheap replacement after xmas then ![Sad Sad](images/smiles/icon_sad.gif)
thanks for the help anyway guys ![Smile Smile](images/smiles/icon_smile.gif)
