Online Now [206]:
Visitors: 205
Today: 78042
Total: 142891472
Forums › The Car › 206 Problems › rear wheel bearing
rear wheel bearing
PostPosted: Fri Dec 17, 2010 5:07 am Up
how can i tell if they need to replace?
atm i can hear high pitch noise coming from the back at all time and all speed, flat road/ bumpy road.
i suspect the bearing is gone, is that possible?
panason1c
PostPosted: Fri Dec 17, 2010 5:10 am Up
Jack up the rear and spin each wheel by hand to listen for any noise and check for any play.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Fri Dec 17, 2010 5:15 am Up
arr...should get this check today Smile
jason_bourne
PostPosted: Fri Dec 17, 2010 7:46 am Up
That sounds familiar - I've just had mine done. I was getting a droning noise from the back from about 35mph upwards.
Who am I?
Werdnal
PostPosted: Fri Dec 17, 2010 7:55 am Up
They can go for a long time being noisy without causing a problem, although they can get hot. Mine showed up at the MOT. If you can hear the familiar drone then they are on their way, but depends on how many long journeys you do, how soon you want to change them. I sold my last car knowing that the bearings were noisy, but unless you had the rear load space cover (estate) open, you couldn't hear it.
Its a fairly easy DIY job, although getting the old bearings out can be a pain.
PostPosted: Fri Dec 17, 2010 8:19 am Up
Yep sounds like its gone.
Cost me £30 including parts to get changed Very Happy
panason1c
PostPosted: Fri Dec 17, 2010 8:23 am Up
Not sure if its a wheel bearing gone in this case, they dont normally make a 'high pitched noise' when gone, more of a 'droning' noise.........might be one of the shoe retaining springs come adrift inside the drum, or if its a disc brake you might have a small road chipping caught between the disc and the caliper causing the noise in which case try reversing a little way to see if it dislodges.
BMW K1200RS
PostPosted: Sat Dec 18, 2010 5:30 pm Up
problem found. nothing wrong with the bearing but is one of the nut in my battery box is loosen, keep rubbing against the metal battery tray Laughing
