Online Now [593]:
Visitors: 592
Today: 64667
Total: 145027110
Forums › The Car › 206 Problems › struggling to pick up speed?
Go to page Previous  1, 2
PostPosted: Sat Dec 18, 2010 3:27 pm Up
Disconnect the bottom intake pipe from where the airbox picks up air
That may be blocked, or remove the airbox completely (temperaly though, as it will need a filter)
grantjohn1979
PostPosted: Sat Dec 18, 2010 4:18 pm Up
just had a look up on limp mode will have to get diagnostics done at peugeot and see if they can erase any faults on the ecu? and see what they say from there?
n/a
grantjohn1979
PostPosted: Sun Dec 19, 2010 5:12 am Up
if i get peugeot to do a diagnostics can they tell the car is in limp mode ?from what ive read about it might be one of the sensors that sends a signal to the ecu and the ecu goes into limp mode and kind of makes the car lack power and speed so the car as such dosent get ruined?if theyfind any fault codes do these get wiped off the ecu when they do the diagnostics thanks guys
n/a
Page 2 of 2
