Online Now [563]:
Visitors: 562
Today: 153372
Total: 146855887
Forums › The Car › 206 Problems › HELP NEEDED
HELP NEEDED
Allen_206
PostPosted: Sun Dec 19, 2010 10:42 am Up
hi people just need some advice as my washers have stopped working on my car . i have checked the fuses and they are all ok. as i thought the fuse would blow before the motor burns out . if the motor does need changing how hard are they to get at and change Crying or Very sad
any advice would be great.
Dabamash
PostPosted: Sun Dec 19, 2010 10:46 am Up
Staff - Daba
You sure they're not just frozen?
I know, stupid suggestion, but it's possible.
PostPosted: Sun Dec 19, 2010 10:48 am Up
:what-dip-s**t-said:
Laughing
Andrew
PostPosted: Sun Dec 19, 2010 10:53 am Up
Put some de-icer on the nossles and sit with the engine running for 15 mins, I thought mine were broken because I even had de-icer screen wash in there but it was still frozen for days, it just takes a hell of a lot of thawing out
My 206 thread
www.detailedbyandrew.com
Allen_206
PostPosted: Sun Dec 19, 2010 10:56 am Up
cheers ill give it a go
PostPosted: Sun Dec 19, 2010 11:06 am Up
Also use a needle to poke around inside them
Allen_206
PostPosted: Sun Dec 19, 2010 11:09 am Up
its the pump thats not working
PostPosted: Sun Dec 19, 2010 11:10 am Up
is the water frozen in the tank? might be reason why pump wont work, or may have burnt out if you been trying it alot while frozen?
Allen_206
PostPosted: Sun Dec 19, 2010 11:34 am Up
not sure if it was frozen forgot to check before i put some more water in .
Lecktorious
PostPosted: Sun Dec 19, 2010 11:36 am Up
Trade Rating: +59
there's your problem.
Use concentrated screenwash.
'98 Nile Blue 306 GTi 6
Allen_206
PostPosted: Sun Dec 19, 2010 11:41 am Up
thanx will put some in tomorrow
eddrj
PostPosted: Sun Dec 19, 2010 11:43 am Up
ive had this few times probably just frozen thats all
Old car 2000/ 206 2.0 hdi.
copey
PostPosted: Sun Dec 19, 2010 11:52 am Up
its prolly frozen, even with the stuff thats suppose to stop if freezing mine still froze up, took around 60mile round trip before it unfroze
02 2.0 hdi d turbo
Rob2859
PostPosted: Sun Dec 19, 2010 2:07 pm Up
or warm water first to defrost it then runm it through and put screenwash in. someone left a full bottle in the carpark at work which i clamed Very Happy
Allen_206
PostPosted: Mon Dec 20, 2010 1:31 pm Up
put 3 full kettle loads in today and still no luck will keep trying
