Latest: S2cgm
Overall: 17178
Online Now [166]:
Visitors: 165
Today: 43394
Total: 137193151
Forums › The Car › 206 Problems › wee pug no starting
wee pug no starting
tamz
PostPosted: Mon Dec 20, 2010 9:58 am Up
help please .... over the past few weeks with all the bad wheather we have had i have benn unable to get my car out the garage , i have been out starting it everyday , i left the car for 2 days then it would not start , i got the battery checked with quickfit , i was nackerd Sad .
I replaced the battery and it still wont start , it is turning over then stopping dead , then i have to turn the key again , i am lost on what can be wrong does anyone have any ideas
doug81
PostPosted: Mon Dec 20, 2010 12:02 pm Up
No idea's but I have the same problem, proper doing my head in!!
www.sparklemyworld.co.uk
tamz
PostPosted: Mon Dec 20, 2010 7:35 pm Up
am going to take the starter out tomoz and replace it see if that makes a differance
Antknee
PostPosted: Mon Dec 20, 2010 7:39 pm Up
does it start at all if you jump start it?
also quick fit would probably say that to get you to fork out anyway D:
giveitsomebar
PostPosted: Mon Dec 20, 2010 7:45 pm Up
more details? if its a diesel the diesel could of frozen?
tamz
PostPosted: Mon Dec 20, 2010 7:51 pm Up
ive never tried to jump start it , as it nose first in the garage and my garage is at the bottom of a hill lol cant get it out , i didnt buy the battery from quickfit they tested it and it wasnt holding a charge and i had charged it b4 i took it to them
tamz
PostPosted: Mon Dec 20, 2010 7:53 pm Up
soz man its converted to a 1.6vtr lol petrol ,
PostPosted: Tue Dec 21, 2010 2:20 am Up
When u say does nothing are the dash lights dimming ?
tamz
PostPosted: Tue Dec 21, 2010 6:32 am Up
alll lights are fine mate , its like the engine just stops dead Mad until you turn ignition off and turn the key again
giveitsomebar
PostPosted: Tue Dec 21, 2010 7:05 am Up
so you turn the key it trys to turn over then stops and does nothing?
check the earth strap ontop of the gearbox
check there is anti freeze in it , it could of cracked the block an lost compression!
check the terminals are on the battery properly and not cracked at all
check both wire are on the starter motor ok and give it a tap with a crowbar or something when it stops turning over
if all of that seems ok, go back to the basics get a spark plug out put it in the end of the lead and rest it on the engine somewhere (its got to be earthed and dont hold it you get a smack!) turn it over and see if it sparks if it does put it back in. then loosen the fuel rail pull it off carefully and turn it over make sure all 4 injectors are fueling
if the spark plugs are not sparking then your looking at coil / plugs / leads / earths
if the injectors arnt working properly your looking at blocked injectors / blocked fuel line / shagged fuel pump or something worse but try the above first and get back to us when your done and have the results and were try help you further
