Latest: Beduff1977
Overall: 17134
Online Now [275]:
Visitors: 274
Today: 57886
Total: 107370171
Forums › The Car › 206 Problems › car reading 5mph when at stop
mjsroofing
PostPosted: Fri Dec 17, 2010 8:37 am Up
i think so, just make sure that nothing is opened etc between removing the key, disconnecting the battery and turning on the side lights
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
troy
PostPosted: Wed Dec 22, 2010 1:24 pm Up
tried a bsi reset again and it still hasnt helped. here is a picture to show where the speedo is sitting at the moment.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
PostPosted: Wed Dec 22, 2010 1:29 pm Up
You tried unplugging the instrument cluster for a few seconds?
troy
PostPosted: Wed Dec 22, 2010 1:32 pm Up
ye have tried that, when i unplug it and plug it back in its exactly the same. is there a way to re-calibrate them as i know there is on renaults?
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Wed Dec 22, 2010 1:34 pm Up
How many miles has the cluster done?
Is it running the latest BSI software from Peugeot?
troy
PostPosted: Wed Dec 22, 2010 1:40 pm Up
cluster has done just over 50k i have no idea what software the bsi is running, how do you find out ?
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Wed Dec 22, 2010 1:44 pm Up
This really needs a scan with Peugeot Planet diagnostic software.
You could also try another cluster if you can find a lower mileage one.
troy
PostPosted: Wed Dec 22, 2010 2:05 pm Up
il give it another scan with my snap on ethos when im back in work but i doubt it will do much.
just to confirm, you do agree that the dial is over the 0mph mark do you? lol
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Wed Dec 22, 2010 2:10 pm Up
Your wasting your time using a Snap On Ethos to scan this.
You need to use Peugeot Planet Wink
troy
PostPosted: Wed Dec 22, 2010 4:09 pm Up
is peugeot planet the system they use in peugeot? as i can see that it is able to download off the internet, do you know if i was to download this then how would i connect the car to the pc, is there a usb-eobd socket lead?
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
panason1c
PostPosted: Thu Dec 23, 2010 1:10 am Up
I would drive the car and use a sat-nav to check the accuracy of the speedo at varying speeds, if is very close to what the sat-nav reads then i wouldnt worry about it. However, if the speedo is showing 5 mph too fast at any given speed then it could be the speedo needle has come loose on its spindle and just needs manually repositioning (strip the cluster down).
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Thu Dec 23, 2010 5:19 am Up
Yes.
troy
PostPosted: Thu Dec 23, 2010 9:38 am Up
ok so i plugged my works ethos in today and i have the folowing eorrs
engine- vehicle speed
air mass (now replaced)
abs- vehicle speed
left front sensor and/or ring (ring is cracked being replaced 28th)
airbag- vehicle speed
im guessing something is going wrong with the vehicle speed, im going to replace the abs ring when i go back to work and then contact peugeot then.
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
PostPosted: Thu Dec 23, 2010 9:39 am Up
So are the airbag & abs warning lights on then?
Speedo takes its signal from n/s front ABS sensor Wink
troy
PostPosted: Thu Dec 23, 2010 9:45 am Up
abs light is on and the airbag light also came on yesterday. im going to replace the ring but i cant see that the speedo will zero by itself. once i replace the sensor i will try a bsi reset again
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
Page 2 of 3
