Posted: Fri Dec 17, 2010 8:37 am |
i think so, just make sure that nothing is opened etc between removing the key, disconnecting the battery and turning on the side lights
| | ![](images/spacer.gif) |
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Wed Dec 22, 2010 1:24 pm |
tried a bsi reset again and it still hasnt helped. here is a picture to show where the speedo is sitting at the moment.
![](http://i47.photobucket.com/albums/f171/normal-people-scare-me/Photo0116.jpg~original)
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Wed Dec 22, 2010 1:29 pm |
You tried unplugging the instrument cluster for a few seconds?
Posted: Wed Dec 22, 2010 1:32 pm |
ye have tried that, when i unplug it and plug it back in its exactly the same. is there a way to re-calibrate them as i know there is on renaults?
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Wed Dec 22, 2010 1:34 pm |
How many miles has the cluster done?
Is it running the latest BSI software from Peugeot?
Posted: Wed Dec 22, 2010 1:40 pm |
cluster has done just over 50k i have no idea what software the bsi is running, how do you find out ?
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Wed Dec 22, 2010 1:44 pm |
This really needs a scan with Peugeot Planet diagnostic software.
You could also try another cluster if you can find a lower mileage one.
Posted: Wed Dec 22, 2010 2:05 pm |
il give it another scan with my snap on ethos when im back in work but i doubt it will do much.
just to confirm, you do agree that the dial is over the 0mph mark do you? lol
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Wed Dec 22, 2010 2:10 pm |
Your wasting your time using a Snap On Ethos to scan this.
You need to use Peugeot Planet ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Wed Dec 22, 2010 4:09 pm |
is peugeot planet the system they use in peugeot? as i can see that it is able to download off the internet, do you know if i was to download this then how would i connect the car to the pc, is there a usb-eobd socket lead?
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Thu Dec 23, 2010 1:10 am |
I would drive the car and use a sat-nav to check the accuracy of the speedo at varying speeds, if is very close to what the sat-nav reads then i wouldnt worry about it. However, if the speedo is showing 5 mph too fast at any given speed then it could be the speedo needle has come loose on its spindle and just needs manually repositioning (strip the cluster down).
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Thu Dec 23, 2010 5:19 am |
troy wrote: |
is peugeot planet the system they use in peugeot? |
Yes.
Posted: Thu Dec 23, 2010 9:38 am |
ok so i plugged my works ethos in today and i have the folowing eorrs
engine- vehicle speed
air mass (now replaced)
abs- vehicle speed
left front sensor and/or ring (ring is cracked being replaced 28th)
airbag- vehicle speed
im guessing something is going wrong with the vehicle speed, im going to replace the abs ring when i go back to work and then contact peugeot then.
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
Posted: Thu Dec 23, 2010 9:39 am |
So are the airbag & abs warning lights on then?
Speedo takes its signal from n/s front ABS sensor ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Thu Dec 23, 2010 9:45 am |
abs light is on and the airbag light also came on yesterday. im going to replace the ring but i cant see that the speedo will zero by itself. once i replace the sensor i will try a bsi reset again
| 2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd | |
