Online Now [677]:
Visitors: 676
Today: 8201
Total: 145692056
Forums › The Car › 206 Problems › Another non starter
Another non starter
Spanerman
PostPosted: Thu Dec 23, 2010 4:46 pm Up
Right, this afternoon i had the battery disconnected to install an amp, and now it wont start
Some details:
Turns over
All lights are on as usual
No sound from fuel pump
Big red button is fine
BSI Reset has been done
Is there any way to test the fuel pump from inside the car, i have an install covering the hatch to access it! ffs lol
Ps, all fueses are fine
Please Help! Sam.
Hello
Spanerman
PostPosted: Thu Dec 23, 2010 5:07 pm Up
Some more info.
The 4 wires going into the pump area read
0v
0v
0v
3v (which i assume is the supply for the fuel level sender)
Sam.
Hello
panason1c
PostPosted: Fri Dec 24, 2010 3:56 am Up
Everything points to a fuse blown during the installation, i would be checking the fuses again and looking for an independant' fuse possibly missed the first time.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Jon
PostPosted: Fri Dec 24, 2010 4:03 am Up
Get ya multimeter out and check the feeds to your fusebox in the engine bay, starter motor etc
Alpine 9887r
Genesis Profile 2 > JL C2 Components
Vibe BlackAir 12" Active
Spanerman
PostPosted: Fri Dec 24, 2010 6:52 am Up
No fuses gone.
main feed is ok, there is no feed from the multi function relay to the fuse box, so this points towards the relay or whatever controls it, ECU?
Sam.
Hello
PostPosted: Fri Dec 24, 2010 6:58 am Up
Is the key in ignition warning still working when you open the drivers door with the ignition turned OFF?
Spanerman
PostPosted: Fri Dec 24, 2010 7:01 am Up
Yes it is
Hello
PostPosted: Fri Dec 24, 2010 7:03 am Up
Then the immobiliser is working correctly then.
If your sure its not a fuse then replace the multifunction relay
