Posted: Fri Dec 24, 2010 7:23 am |
Dabamash wrote: |
Haha, seems worth a go. Let the MSA b***h about that instead.
Shame though, I like the bi-plane on your pug  |
me too.... kind of suited the look.... bugger all good as a spoiler. I would get more downforce with a fly sat on the bumper
Posted: Fri Dec 24, 2010 7:26 am |
So. Plastic back window with a GTI spoiler then?
Posted: Fri Dec 24, 2010 7:28 am |
Don't worry about the paint job...the tailgate is bound to get mangled when you go backwards into a forest anyway!
Posted: Fri Dec 24, 2010 7:29 am |
Edward wrote: |
Don't worry about the paint job...the tailgate is bound to get mangled when you go backwards into a forest anyway! |
Don't forget upside down
Posted: Fri Dec 24, 2010 7:32 am |
dont you lot start on me..... one of the mechanics keeps telling me he is going to put "hello mum" on the underside for the photographers
Posted: Fri Dec 24, 2010 7:47 am |
Im sure you will be fine Mac.
New window and GTi spoiler and your sorted, saying that the GT wasnt speced with a spoiler as it was an optional extra.
Posted: Fri Dec 24, 2010 7:48 am |
Thats handy.... have you got details of the options offered
Posted: Fri Dec 24, 2010 7:51 am |
I can have a look and see if I can find them......
Posted: Fri Dec 24, 2010 7:56 am |
That would be massive.... top man, would love to see the MSA faces if I can find an optional spoiler with downforce characteristics
Posted: Fri Dec 24, 2010 10:34 am |
The bi planbe is usually just bolted on the bolts are a little tricky to get to you will find them hiding behind the wiring rubbers on each side of the tail gate 10mm iirc. Although I have seen these boned as well as the bolts really don't look man enough to hold the spoiler on
Posted: Fri Dec 24, 2010 12:48 pm |
If its tigerseal then just cut it off with a big knife. Then sand and spray that small top section. that would be the cheapest option. Shame though that spoiler really suits your car.
