Online Now [549]:
Visitors: 548
Today: 132103
Total: 105574044
Forums › The Car › 206 Problems › Climate Control On Full Uses Too Much Volts
PostPosted: Fri Dec 24, 2010 2:08 pm Up
Morning peoples,
Bit of a problem, every time i turn the climate control up to full it eats most of the voltage of my system taking it down from 14.3 to 12 or sometimes 11 volts
I can have it just one fan below the maximum but it doesnt really blow out much and then on full whack it melts your face?
I even put on a merc 110 ah battery on to see if mine was at fault, but no it still managed to drop that too Neutral
Any ideas?
Ps the fan squeeks alot to
panason1c
PostPosted: Fri Dec 24, 2010 2:12 pm Up
Might be the fan blower motor bearings seizing and causing the motor to draw too many amps.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Fri Dec 24, 2010 2:13 pm Up
What's the problem?
I was thinking that, any advice on how to change it?
PostPosted: Fri Dec 24, 2010 2:16 pm Up
E5GDM wrote:
What's the problem?
It drops the volts to much, problems for people who funny enough like 14.4 volts for ICE Wink
namgaj
PostPosted: Fri Dec 24, 2010 2:25 pm Up
Might be because you installed climate control yourself and f****d it up!! LOL Razz
4.0 V8 S-Type Jaguar
mjsroofing
PostPosted: Fri Dec 24, 2010 2:39 pm Up
would it not be that thing bolted to the heater matrix starting to burn out, help me out guys, whats it called, some one else had a problem with one the other day.
it controls the amount of voltage that goes to the motor to give you the different speeds
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Ash
PostPosted: Fri Dec 24, 2010 3:54 pm Up
Laughing
PostPosted: Sat Dec 25, 2010 5:12 am Up
Take the glove box out & have a look, fans at the top of the dash in the middle.
PostPosted: Sat Dec 25, 2010 7:05 am Up
Ash wrote:
Laughing
Yeh probaly
Might aswell check it today, sick of christmas already
namgaj
PostPosted: Sat Dec 25, 2010 7:11 am Up
Aww come on addaz cheer up lad Razz I'll flash you my moobs if it'l raise a smile Smile
PostPosted: Sat Dec 25, 2010 7:29 am Up
Dont think that will make me smile mate, not sure anything will for sometime now
