Latest: Beduff1977
Overall: 17134
Online Now [687]:
Visitors: 686
Today: 184295
Total: 108520388
Forums › The Car › 206 Problems › the cold overheated my engine
Rob2859
PostPosted: Sun Dec 26, 2010 12:54 pm Up
At 8am yesterday my engine was quite hot so I thought I would put my foot down to bring more cold air into the rad but that saw the temp shoot up and the stop light beeped at me (about 110 at this point). I stopped and let it cool down and it was fine after.
The top rad pipe was warm but it seemed to be dripping water from the expansion tank for some reason. (Still enough in it). The fan clattered and banged away as normal until the engine cooled down.
Is it likely the rad is blocked?
The engine should be okay?
kieron
PostPosted: Sun Dec 26, 2010 1:07 pm Up
if it was at 110 it would of melted any ice that was in the system anyway? first thing i would check is to see if your thermostat is working its easy to test
Account suspended
EuroPeugeot
PostPosted: Sun Dec 26, 2010 2:57 pm Up
How do you test one? Smile
PostPosted: Sun Dec 26, 2010 3:18 pm Up
There cheap enough to throw in the bin & replace with a new one.
Rob2859
PostPosted: Sun Dec 26, 2010 8:14 pm Up
was thrashing it on the back roads on the way back from lancashire tonight and it seemed fine so will leave it for now.
panason1c
PostPosted: Sun Dec 26, 2010 11:23 pm Up
Sounds like you had a partial freezing of your coolant due to a weak mix, get the antifreeze strength checked.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Antix
PostPosted: Mon Dec 27, 2010 2:07 am Up
Custom - Red Stars
The dripping was probably the engine sweating, especially doing 110.
kieron
PostPosted: Mon Dec 27, 2010 3:37 am Up
by taking it out and puting it in a bowl of boiling water out of a kettle you will see it open and when you take it out it will close slowly if it dont do that its faulty
Account suspended
Contax
PostPosted: Wed Dec 29, 2010 9:06 pm Up
I was worried about starting my 1.4 HDi in this cold weather so left it 'till thaw came as I read a frozen water pump can strip teeth off timing belt, I put a sample from expansion tank in freezer at -21C and still liquid so I used turkey baster to suck half a litre out of expassion tank and topped with neat antifreeze, I hope it mixes in when it gets hot, bit extra can't do no harm I hope, Used to do the boiling water on thermostat when I was young and repaired my own motor.
I don\'t feel old. I don\'t feel anything until noon. Then it\'s time for my nap.
gixxerkev
PostPosted: Thu Dec 30, 2010 2:06 am Up
Its all very well dropping the stat into boiling water and watching it open but you really need to heat the water up slowly and measure the temperature of the water when the stat opens to make sure its opening at the correct temperature. This temperature, on average, is about 81-85 degrees.
An Ex '03 1.4 GLX driver, German technology all the way now.
