Online Now [144]:
Visitors: 143
Today: 6051
Total: 127759235
Forums › The Car › 206 Problems › Perished Pipe.
Perished Pipe.
00budham00
PostPosted: Mon Dec 27, 2010 10:00 am Up
One of the pipes on my engine is perished, and is not looking so good.
What is the pipe called so I can get it replaced, and what does it do?
Have circled it in yellow. Thanks.
Mattie-RS
PostPosted: Mon Dec 27, 2010 10:54 am Up
I think thats the oil breather hose
mjsroofing
PostPosted: Mon Dec 27, 2010 11:03 am Up
cam flow pipe i call it, as above i'm sure its a oil breather pipe from the rocker cover to the air inlet
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Mon Dec 27, 2010 11:38 am Up
Could swop it for a length of silicon hosing from Ebay...I think you'll need a little T piece in it though. I bet it's not cheap from the dealer. You can cut the pipe up to re-use the end connectors.
Mine just needed a straight run but I reckon you could use the existing angled T piece.
