Online Now [67]:
Visitors: 66
Today: 24565
Total: 105032970
Forums › The Car › 206 Problems › Repair or not to repair!?
doug81
PostPosted: Mon Dec 27, 2010 12:39 pm Up
Merry Christmas All,
I have more problems with my dreaded Pug, I've not been able to start it now for the past two weeks and after getting a mobile mechanic out (on Christmas eve....thankyou!!) he's told me that there's a fault with the ecu. My question to you guys is can ecu's be refurbished? If so how much? Or is it more sensible to get a new one? Well scrapyard one!
www.sparklemyworld.co.uk
PostPosted: Mon Dec 27, 2010 12:41 pm Up
Scrapyard / 2nd hand unit will be locked because of the immobiliser
You would need someone with the correct kit to code it in to your car before it will work.
What fault with the ecu did the mobile mechanic say you have?
doug81
PostPosted: Mon Dec 27, 2010 12:43 pm Up
Hello again again MrBSI, He's not given me a specific fault just that one of the outputs doesn't work.
PostPosted: Mon Dec 27, 2010 12:45 pm Up
This lot can test & repair ecu's
www.bba-reman.com/uk/index.aspx
doug81
PostPosted: Mon Dec 27, 2010 12:47 pm Up
Thankyou mate
mjsroofing
PostPosted: Mon Dec 27, 2010 1:27 pm Up
i dont know if this relates to your problem but i have seen a this kind of problem with 206's a couple of times, they will not start or seem to run out of fuel while driving, well it has a few symptons, when pluged in no faults are found or no ecu found, it turns out to be a fault/break in a wire in the loom that goes around the engine, the cover on the top of the engine rubs against the loom and forms a break in the wire.
well worth a look mate, i didnt see the problem my self so thats all i know, but just check the wires for any damage.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
doug81
PostPosted: Mon Dec 27, 2010 1:53 pm Up
Oh sound cheers mate, is there anyway I can test the circuits or is it just a case of looking for physical damage?
mjsroofing
PostPosted: Mon Dec 27, 2010 1:57 pm Up
as far as i know its just a case of looking but useing a continuty tester wont hert
Mark
What car is it? I have everything for a straight swap (no work required) so it will run fine, that if it's definately the ecu thats the problem.
doug81
PostPosted: Mon Dec 27, 2010 2:57 pm Up
Its a 1.6xs on a 2000....will go out and look for damage in the light
