Latest: cogeim7
Overall: 17185
Online Now [583]:
Visitors: 582
Today: 16555
Total: 147143745
Forums › The Car › 206 Talk › Where would i find the ECU or the ECU number on my 206
Forum Index › 206 Talk
russman
PostPosted: Tue Dec 28, 2010 6:21 am Up
Hi everyone,
I need help, i've been looking online for ages and looking over my car, I need to find my ECU number...
Does anone know where the ECU is on a 206? or how to get to it?
Cheers
Thanks,\r\nRussell
PostPosted: Tue Dec 28, 2010 6:50 am Up
Its the square bit with the black stripe hanging off on the left, under the plastic vent.
russman
PostPosted: Tue Dec 28, 2010 7:06 am Up
Cheers mate
Thanks,\r\nRussell
PostPosted: Tue Dec 28, 2010 9:49 am Up
Going by your previous threads are you 100% sure the ecu is actually faulty?
Might be worth getting the car hooked up to Peugeot Planet diagnostic & seeing whats up with it.
russman
PostPosted: Tue Dec 28, 2010 10:00 am Up
umm thats the slight probably mate, i've put it on the dignaostics, 2 or 3 times latly the first time i put it on it it came up with a "engine management sensor" and a "camshaft positioning sensor" needed replacing, did these but it still ticking over quite high.
i have a "idle positioning sensor" on the way if that doesnt work the garage is thinking maybe the ECU might be at fault.
Thanks,\r\nRussell
PostPosted: Tue Dec 28, 2010 10:03 am Up
Was it a Peugeot / Citroen main dealer diagnostic?
PostPosted: Tue Dec 28, 2010 10:58 am Up
I very much doubt its the ECU, you would be having more problems than a high idle.
mjsroofing
PostPosted: Tue Dec 28, 2010 5:17 pm Up
i wouldn't say its the ecu, dirty sensor, have you cleaned all the connectors (uplug, wd40 plug in and out)
sorry didnt get if it was diesel or petrol but if petrol clean throttle body etc
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
mattievrs
PostPosted: Tue Dec 28, 2010 6:06 pm Up
I had a similar issue with my xsi.I used carb cleaner on the throttle housing,butterfly.map sensor and then sprayed some down the throttle whilst revving it.Sorted it out a treat.
NO LONGER ACTIVE ON THE FORUM
Brian
PostPosted: Tue Dec 28, 2010 6:18 pm Up
Trade Rating: +31
Have you had a poke around the throttle body/throttle cable?
russman
PostPosted: Tue Dec 28, 2010 6:28 pm Up
The high idleing is the start of all the problems, sometimes it will start first times other times it takes 3 attempts to start it, really quite annoying, i've tried all the sensors, the throttle body has been clean twice. (just for good messure) Smile
Yea sorry my car is a 206, 2005, 1.4 sport (petrol). The garage that has been looking at my car and finding my car a "one of a kind" is a authorised peugeot dealers.
Thanks,\r\nRussell
mattievrs
PostPosted: Tue Dec 28, 2010 6:34 pm Up
cleaned the map sensor?
russman
PostPosted: Tue Dec 28, 2010 6:45 pm Up
havnt thought about that do you know where it might be...
Cheers
Thanks,\r\nRussell
mattievrs
PostPosted: Tue Dec 28, 2010 6:51 pm Up
same on a 16v engine too.
russman
PostPosted: Wed Dec 29, 2010 8:56 am Up
if i happened to get a ECU as long as it is for a 1.4i would it be ok for the 8v and the 16v to use the same one or would they have to be different ECU's?
Thanks,\r\nRussell
